Reverse gear grinding noise. TD5 - Defender Source
Old October 22nd, 2012, 03:01 AM
JackDEF90's Avatar
JackDEF90
Jack Nicholls
2002 Defender 90 station wag 2.5 D
Hi,
First thing in the morning and really if the engine has been off for 9 + hours. I have noticed that after I have started the D90 TD5, and put it in to reverse the car sounds like gears are grinding slightly. This will literally only happen for that point and then or seems fine..... Any suggestions as to what and why this happens?
Old October 22nd, 2012, 07:06 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Have you checked the gear oil level? You have the R380 right?
Land Rover 110
Old October 22nd, 2012, 07:36 AM
If first is the first gear you select does it crunch? What oil are you using?
Old October 22nd, 2012, 03:49 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
DO you feel it vibrate through the clutch pedal? it does it as well if you're holding the vehicle on the clutch or pulling away?
In which case, it's a normal Td5 thing.... to do with the spigot bush in the end of the crank. When you've got the engine or gearbox out next time, just change it.
You may find it'll stop doing it after a while. Both mine did it from new, then eventually bedded in.
Others do it after many thousands of miles. but it usually stops.
td5
Noise going into reverse ADK46er Defender Technical Discussions 4 October 14th, 2011 02:35 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
reverse gear... Gkase Defender Technical Discussions 1 September 29th, 2004 06:13 PM
Grinding into Second Gear? azdefender Defender Technical Discussions 4 March 9th, 2004 01:44 AM
