Reverse and Fog Light Inop - Defender Source
Old July 9th, 2012, 05:11 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I recently replaced the old rectangular reverse and fog lamps on my '85 ROW 110 with the round "NAS" style lamps. The lamps were working fine before the swap. The new lamps do not work at all. The bulbs are fine and I've checked the wiring and bullet connectors and they are fine too. I haven't checked the reverse switch on the gearbox or the fog light switch on the steering column, so these might be the culprits.
Any other suggestions for what might be the problem? The fog lamp symbol lights up on the dash warning panel when I actuate the fog lamp switch, but the lamp itself does not illuminate.
FYI, I also replaced all bulbs with LEDs and changed the flasher module as well. Not sure if this has an impact on the reverse/fog not working.
ATW!
- Jon
Old July 9th, 2012, 05:14 PM
texrover's Avatar
texrover
Jason
I'm sure I'm asking the obvious, but, did you check the fuse box?
And I'm anxious to hear other responses b/c I have to track down same issues as well for the 110.
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 9th, 2012, 05:15 PM
Probably has to do with the LEDs.
Old July 9th, 2012, 05:16 PM
defeyago's Avatar
defeyago
Santiago
ī96 Defender 110 VGTdi SW County
Change the lights connecting wires around. LED lamps have polarity and if they are inverted they just donīt work. Try switching to regular bulbs on reverse and fog and if the work itīs just a polarity issue with the LEDs.
SANTIAGO
ī97 Defender 110 Tdi SW
ī04 Freelander Td4 5 dr.
ī97 Alfa Romeo 146 TD (Sold)
ī95 Volvo 850 GLT Estate
ī94 Discovery Tdi (Webasto equipped)
Old July 9th, 2012, 05:26 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I did check the fuse box and there aren't any blown fuses. I also put an incandescent bulb back in and it still didn't work. I used the 1156-45 LED bulbs from superbright LEDs.
ATW!
- Jon
Old July 9th, 2012, 09:14 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
You guys were right. Ended up being a polarity issue. Which is weird, as all of the other LED bulbs were plug and play without issue. I ended up re-splicing the wires and they work just fine now. Thanks!
ATW!
- Jon
Old July 9th, 2012, 10:46 PM
Off topic...but where'd you get the round style lights from?
Old July 10th, 2012, 02:54 AM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
I ordered them from http://www.brit-car.co.uk/. They had OEM lamps, cheaper than genuine LR, and not shitty Britpart. They came with the mounting plinths too. I had to order the econoseal connectors separately. I went ahead and replaced my indicator side repeaters as well, with the clear TD5 units.
ATW!
- Jon
ht
Trailer Wiring Harness duderight Defender Technical Discussions 3 July 13th, 2011 10:33 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
1997 White D90 SW, 29500 Miles Steve Friedman For Sale - Vehicles 1 December 14th, 2006 01:54 PM
Reverse Lamp Switch Wiring fleabus Defender Technical Discussions 7 April 16th, 2006 11:58 AM
