Reuse Cylinder Head and Main Bearing Bolts - Defender Source
Old March 22nd, 2016, 02:33 PM
nengelbrecht6's Avatar
nengelbrecht6
Nick Engelbrecht
2005 LR3 SE "No Name Yet"
I am replacing head gaskets and wanted to know if I can reuse the bolts or if I should buy new bolts or studs.
Also, going to replace rear main seal and cross seals while I've got the engine out. Can I reuse the main bearing cap bolts or should i buy new bolts or studs for this as well?
Nick
KM6FDZ
2005 LR3 SE
Old March 22nd, 2016, 02:38 PM
You should probably read the manual if you are pulling the engine apart. It answers all questions.
Old March 22nd, 2016, 02:41 PM
nengelbrecht6
Nick Engelbrecht
This is what the V8 Overhaul manual says about bolts:
CAUTION: Cylinder head bolts - Cylinder head bolts fitted to engines without suffix B added to serial number are not interchangeable with those fitted to engines with suffix B added to serial number.
Nick
KM6FDZ
2005 LR3 SE
Old March 22nd, 2016, 02:48 PM
Its pretty simple. If you are using the crappy steel shim head gaskets with head bolts that have washers yes you can reuse the head bolts. If you are using the way better elring or similar update composite gaskets you need to get the newer flanged stretch type head bolts. Do not use the washers with the new flanged head bolts.
Originally Posted by nengelbrecht6 View Post
i am replacing head gaskets and wanted to know if i can reuse the bolts or if i should buy new bolts or studs.
nooooooooooooooooooooooooooooo....
[breath]
oooooooooooooooooooooooo!!!!!!!!!!!!!!
Mark Kellgren
KM4BOR
Old March 22nd, 2016, 03:20 PM
I've done it before, and I know of a few others that have as well. Its definitely not the correct way, but it works in a pinch. Don't use studs.
Old March 22nd, 2016, 03:33 PM
Listen to Doug.... A 3.5 would have had regular reusable head bolts.... These need to be torqued.... Later engines switched to torque to yield bolts. These are different bolts and are set by amount of angle. Different bolts, different procedures. Don't mix up the two types and methods.
Personally I'm not sure of a great reason to switch to the newer style. All of these head gasket failures were unheard of on Rover V8s until the late 90s.
Old March 22nd, 2016, 04:47 PM
my .02.
The std 3.5 was a low compression pig.
It wakes up when you put later heads on and use the composite gaskets. You up the compression ratio, gain larger valves, loose the problematic lower row of head bolts etc.
Old March 22nd, 2016, 06:01 PM
In my experience the composite gaskets just leak coolant externally, where the steel gaskets blow out completely.
But if you reuse the original heads and install the composite gasket you lower the compression.
Needed: 300tdi Rocker assmebly and cylinder head. Alaskaptain Wanted 1 January 31st, 2015 02:47 PM
Assembling engine--center main bearing won't fit Davis Defender Technical Discussions 1 March 30th, 2010 09:49 AM
Assembling engine--center main bearing won't fit Davis Defender Technical Discussions 0 March 20th, 2010 02:40 PM
Can you reuse con rod bolts? Davis Defender Technical Discussions 2 February 26th, 2010 09:03 AM
Southwest Rovers Cylinder Head chris snell Misc. Chit-Chat 1 August 21st, 2007 10:31 AM
