Returning a tranny for repair under warranty - Defender Source
Old July 9th, 2012, 04:09 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
I got an R380 from a well respected vendor. Most of us know their work to be excellent, and I've gotten a perfect LT230 from them. Unfortunately, the gearbox is having shifting issues. I'll say right off the bat that he's been very good about spending time trying to diagnose the problem, and he's always returned my phone calls. I don't have a problem with him at all.
It was installed locally by an ASE certified mechanic, and has only a few hundred miles on it. I'm not asking you guys to diagnose the problem because the mechanic determined that it's not the clutch (fairly new) or shifter bearing wear, so he said it must be in the box. (For those interested, it grinds into second and third gear most of the time but not every time. 2nd is worse. I can make it shift properly almost every time by revving it to about 3000 rpm and let it drop to 2200 before I start to pull it into 2nd.)
Anyway, I've never done this before so I'm wondering what the protocol is for returning it. The vendor already agreed that it should come back to the shop and I'll get reimbursed for the shipping. Is it normal procedure for me to get reimbursed for the mechanic work too, or do I eat that cost? And why does it cost so much to ship a fricking box that takes a week to arrive when I can fly myself (who weighs roughly twice as much and takes up three times the space) to the same location in a few hours for half the cost?
Pete
Old July 9th, 2012, 04:30 PM
Normally you would not be compensated for install times.
As far as shipping, without a bellhousing, it can go fedex oversized for less than $150 as it is under 150lbs.
Old July 10th, 2012, 09:45 AM
peachyracer
Peter Stolz
Thanks. I like to know what I can expect. I couldn't believe how much cheaper FedEx was than UPS.
Pete
Old July 10th, 2012, 10:20 AM
If the shop had provided the tranny, they would cover the labor under warranty. Since you provided it, they are not responsible... You could ask the company you bought it from to help with the cost. Doubt they will, but you never know unless you ask.
Old July 10th, 2012, 11:02 AM
Before you go tearing into it, make sure the shifter is adjusted properly and the clutch is properly bled. I would hate to see you pull it for something like that not internal to the box.
Old July 10th, 2012, 11:09 AM
peachyracer
Peter Stolz
I bled the clutch many times just to be sure, and no air came out. I did need to adjust the shifter spring a bit to get the slop out which helped it go into 4th much better, but it still doesn't do 2nd or 3rd very good. The bearings in there also looked good.
Pete
Old July 10th, 2012, 11:33 AM
Hmmm. Out of interest what fluid are you using in the box?
Old July 10th, 2012, 11:41 AM
peachyracer
Peter Stolz
Redline MTL
Pete
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Wanted, NAS 1995 D-90 (Tranny) Transfer case Roverville Wanted 3 November 28th, 2005 02:14 PM
Wierd tranny question? D90user Defender Technical Discussions 6 November 15th, 2005 10:17 AM
Tranny leak?? mspell Defender Technical Discussions 3 September 8th, 2004 12:43 PM
Warranty Term and Provisions? wicks Defender Technical Discussions 2 December 23rd, 2003 02:23 AM
