Return to center steering damper - Defender Source
Old May 26th, 2011, 01:32 PM
Naplm00
Matthew
Anyone ever use one of these? I figure my PS pump could use all the help it can get.
http://cgi.ebay.com/Land-Rover-Defen...#ht_1289wt_905
Old May 26th, 2011, 01:44 PM
The Dro
Dro
1988 Ninety
I'm no expert, but this looks like it will make the pump fight the damper.
Old May 26th, 2011, 01:46 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
return to center is driven by caster angle. Are you lifted? (or on HD springs?) I found my caster action very weak on HD springs in my 110 (that combined with a sloppy steering box was down right scary), so am going to correct my caster angle when I'm done with all my work - either by modifying my swivels or getting caster correcting arms.
Old May 26th, 2011, 01:47 PM
Naplm00
Matthew
nope im in 285s but i will be going up very soon.
My pump is weak to return and the wheels are weak to return
Old May 26th, 2011, 02:44 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Why not just fix the problem rather than throwing a band aid on it?
Steering dampers are for absorbing shock to the steering, that's all.
Installing that would be like installing new shocks because your springs are worn out.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 26th, 2011, 04:43 PM
TS888's Avatar
TS888
Tony Sims
1984 110
As stated before -- the pump doesn't cause return. The return to center is caused by the steering geometry (caster and toe) and the force of the moving vehicle. If you turn the wheels when stationary, they stay turned.
Tony
1984 110 "Smokey" (sold)
Old May 26th, 2011, 08:02 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Not if you have a magic steering damper.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 26th, 2011, 08:36 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
I installed an Old Man Emu steering stabilizer a couple weeks ago. Replaced the original one. Like Antichrist said, it's not going to fix other steering problems you may be having, but it made a tremendous, noticeable improvement in the steering and overall ride of the truck.
Be careful, for some reason the Old Man Emu stabilizer works great, but people around here have had inconsistent results with the Bilstein version.
Old May 27th, 2011, 05:31 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Arthur C. Clarke's third law -- "Any sufficiently advanced technology is indistinguishable from magic."
Tony
Defender Steering wheel center shawnpalmer Wanted 17 October 17th, 2006 08:06 PM
OME Steering Damper Nut Sergeant_V Defender Technical Discussions 2 September 10th, 2006 04:16 PM
steering wheel center cap shawnpalmer Wanted 3 November 14th, 2005 02:41 PM
Questions regarding Steering damper Mark M Defender Technical Discussions 2 November 20th, 2004 02:45 AM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
