Return of the No start has Spark no Pop - Defender Source
Old December 9th, 2010, 12:52 PM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
So after completing the 2500 mile journey from Kentucky to Washington flawlessly (blown u joint the exception) i deemed it time for a little work. Oil change, all the fluids changed, transmission, t-case and diffs drained and refilled
Fast forward to the first drive post all the work, go to pull away from a light and it starts bucking and dies on the other side of the intersection... an embarrassing push by some jeep owners into a parking lot and about 10 minutes later fired right back up again and ran fine. Got it home and in the driveway, went to move it to diagnose and now nothing again.
I am getting spark at the plugs, and you can smell fuel, won't kick with started fluid even though..
New distributor cap, rotor, ignition module...
Pretty much stumped right now.
Appreciate the input.
Old December 9th, 2010, 02:56 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I had a similiar problem, was intermitted, turned out when it would stall out, it was the fuel pump lead wire inside the chassis, it was shorting or corroded and would only go out sometimes, replaced it and its fine now.
Robert Deniro
start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
No Spark Billakris Defender Technical Discussions 6 August 19th, 2005 12:01 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
