retrofitting a 97 bench seat to 94 - Defender Source
Old April 14th, 2013, 06:12 PM
Carson
Carson Mooney
1994 D90
I mistakingly purchased a 97 Nas bench seat but own a 94. It has all the mounting brackets and belts. Is there any way to retrofit this seat to my 94? thanks
Old April 14th, 2013, 06:13 PM
Yup. I have the instruction sheet somewhere. The only hard part is the mount for the back belt.
Old April 14th, 2013, 06:39 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
What's the difference between the 94 and 97 seats/belts?
Old April 14th, 2013, 06:52 PM
I can't think of any.
Old April 14th, 2013, 07:00 PM
Carson
Carson Mooney
1994 D90
The belts and holes don't seem to match up to me. I have the 95 defender seat install manual (thanks to the "source"), but the holes in my 94 dont seam to match up. I have the front bolts/brackets in, but the seatbelt brackets don't seem to be there, probably means some drilling. I have never had a rear facing seat for my defender so I am just looking for a way to get this thing in. My wife has been asking for a bench seat in it for 4 years and I need to get r'done. thanks for all the responses.
Old April 14th, 2013, 07:01 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Rear facing??
Old April 14th, 2013, 07:13 PM
Carson
Carson Mooney
1994 D90
yes, rear facing
Old April 14th, 2013, 07:14 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Originally Posted by ipgregory View Post
Rear facing??
Should be forward facing.
Old April 14th, 2013, 07:16 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
They are supposed to be forward facing. This is my 97 but do these help at all?
ID:	70145   Click image for larger version
ID:	70147   Click image for larger version
Old April 14th, 2013, 10:06 PM
Carson
Carson Mooney
1994 D90
Yes, I am an idiot. Forward facing!
Old April 14th, 2013, 10:08 PM
You have to put the bracket under the rear floor.
I wish I had the instructions for the retrofit, but it looks like I threw it out.
Old April 14th, 2013, 10:38 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Hey Carson,
If you need the rear seat belt mounts I have extras. I also have the side mounts as well. Made a bunch for someone else and have extras. You will need to drill the rear bed to mount the rear center bracket. This also means you will need to drop the fuel tank but it's not that bad a job. Just let me know.
Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old April 14th, 2013, 10:57 PM
Now is the time for a galvanized gas tank skid plate too.
Old April 14th, 2013, 11:25 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have a 94 and this is how mine is set up:
Under the truck I have two plates. One for each foot of the seat. The bolts go thru the feet, thru the floor, and thru the plate. I have a locknut on each bolt. On 95s and 97s the plate is riveted to the floor and the nuts are captive. It's not a big deal for me as I never take the feet out but if I did I would have to get under the truck to hold the nuts.
As for the seat belt the y belt screws thru the floor into a plate with a captive nut. It is very close to the back of the truck. I don't see why you need to drop the tank to add it. You can drill the hole, slide the plate under the floor and shouldn't have a problem catching it.
Hope that makes sense.
Old April 15th, 2013, 07:46 AM
I think we need pics. He said "seatbelt mounts" not "seatbelt mount" so I figured he meant the two side mounts, not the single Y belt mount.
Anyway, a year or two ago I think Jefhuf started the thread about building all of the mounts for the rear bench seat, and there were A TON of pics that we all put in there to try to figure out any differences between the years. Maybe try to search a few threads, but at the very least post pics up here of what you're talking about.
97, bench
rear bench seat jonny wrench Wanted 10 January 25th, 2006 05:53 PM
Bench seat install in '97 hartop timcd90 Defender Technical Discussions 1 February 15th, 2005 01:57 PM
Rear Bench Seat Ntajeep Wanted 0 June 7th, 2004 12:05 AM
Rear Bench Seat and Front Bumper Joe P For Sale - Parts 7 May 17th, 2004 10:24 PM
Looking for Forward Facing Rear Bench Seat dreone73 Wanted 3 December 4th, 2003 04:44 PM
