Retrieving Capture Nut from Bulkhead - Defender Source
Old January 5th, 2007, 11:04 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Well, it happened. I'm in the middle of replacing the door hinge bolts on the bulkhead and I just dropped one of the capture nuts (the whole metal part including the piece crimped to the bulkhead) down into the cavity. Mind you this is the top one so it could be anywhere down there. I even tied a string to it, but it ripped off when it fell.
I tried to push it down to the bottom hinge holes so it would be easier to get out, but I'm starting to think that the area isn't open all the way down.
Does anyone have any tricks to get this sucker out? It'd be much appreciated!
Old January 5th, 2007, 11:09 AM
Noah's Avatar
Noah
Noah
95 D90 TDI
You can't reach it with one of those telescoping magnetic pencils?
Old January 5th, 2007, 11:22 AM
cellulararrest
Chris Snyder
I can try that. The problem is you can't get straight down there. You need something that bends.
Old January 5th, 2007, 11:45 AM
It goes all the way down.
Clear the mud out at the bottom.
Ron
Old January 5th, 2007, 12:27 PM
cellulararrest
Chris Snyder
Ok. Thanks, Ron. I'll see if I can get it all the way down.
It seems to be stuck on some sort of shelf in there? I dropped another nut down there to see if it would fall all the way down, but still no luck getting the other piece all the way down.
Old January 5th, 2007, 01:35 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I just did the same thing but I had the front fender off. You can then get them with a long set of tweasers. You might have to do the same thing.. errrr which side is it?
Legend in My Own Mind.
Old January 5th, 2007, 01:40 PM
My 84 they go all the way down. I have a magnatic wand and a pair of grabber things on a stick for this. $1 each at the dollar store.
Or just leave it in there and buy a new one. :-)
Old January 5th, 2007, 02:01 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Man it must be the week for that I lost one wednesday night still looking for it.
Eric
Old January 5th, 2007, 02:11 PM
cellulararrest
Chris Snyder
That's sounding like a good idea. Good place to get one?
I see a couple wires up there if I point a flashlight, so chances are it's caught up there. I'm going to have to buy a single nut and that clamp thingy. Pain.
Driver's Side.
Eric
It's so warm no one can help but work on their trucks!
Old January 5th, 2007, 02:37 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
We have them in stock, it's just a pain to buy one when you know where yours is.
http://www.roverparts.com/Parts/4009.cfm
Eric
Old January 5th, 2007, 02:46 PM
cellulararrest
Chris Snyder
I think I might buy 2 or 3 just incase it happens on the other side! Now I just have to find the same size and threaded nut.
Aw I missed having them shipped today! Ah well.
$10.44 to ship three of those things?!
Old January 5th, 2007, 03:41 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
You did miss today's shipping
The little bracket has the nut in it.
I can ship it Priority Mail for less then 1/2 that just let me know.
Cheers
Eric
Eric (231) Riston
Team Leader with over 10 Years Experience
North American Land Rover club liaison
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old January 5th, 2007, 03:45 PM
Before you do this, stick the garden hose in the top and flood the sucker down!!!!
Old January 5th, 2007, 03:58 PM
cellulararrest
Chris Snyder
The nut that comes with probably won't fit the new stainless bolts I was intalling. My kit came with new ones as the thread pattern is different than the originals.
Old January 5th, 2007, 06:13 PM
FYI everyone, the stainless ones I sold are 5/16" with 18 Threads per inch. Stock is 8mm, but using the 5/16 (which is within mils of being the same) allows replacement of the square nut in the J-nut holder, so there is a stainless nut for the stainless bolt which means less chance for corrosion.
It can be a hassle, but you can get those nuts out with a combo of unbent coat hangers, and whatever other tools you like. There is a little flange inside the bulkhead, but its easy to get things to fall off of it.
Old January 5th, 2007, 09:30 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
After changing out my hardware, my door doesn't exactly line up the way it used to. I haven't fiddled with it much. Anyone got any tricks for getting it line back up? It doesn't look any different, just a little tough to open at times.
Old January 6th, 2007, 01:27 AM
If you didnt get the J-nuts positioned in the same places they were previously, then you'll definitely have thrown the alignment off, since the hinges will tighten down in slightly different places.
If you havent moved the striker on the door jam, you shouldnt be too far off. Loosen the hinges on the bulkhead side slightly and use a rubber mallet to tap them around to achieve better placement. The door often moves too far forward or back and the hinges need to be finessed into postition.
vin
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
» Defender Registry
Grover
Cobramax
Cella
D110DC
Add your Defender
