Restoring 110 salisbury axle - Defender Source
Old June 19th, 2009, 01:56 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
So I started the tear down of the old 110 rear axle and have some questions.
First off any advice on best way to clean it up and paint/powder coat the housing?
It seems like it could use a good sand blasting to begin with. Any issues with blasting it and would powder coat or paint be a better option?
I need to put 4:10's in it and an air locker. I have been to Rover tracks site a ton and it says any Dana 60 gears can be used. Is that correct across the board?
Thanks!
Tyler
Old June 19th, 2009, 02:04 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
My opinion...
1. Sand Blast
2. Paint, cheaper and easier to touch up.
3. Dana 60 locker will fit a 110 Sals either you can go with 24 spline or upgrade to 31 or 35 spline axles but you will have to use modified hubs on the 31s and 35s.
Old June 19th, 2009, 02:15 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I took the advice of Mercedesrover over on Expedition Portal for painting the axle case and:
1. Got all the loose rust off with a wire wheel
2. Left the good black painted areas alone
3. Washed with good degreaser and water
4. washed down with brake cleaner
5. painted with SEM rust shield 38061 Gloss Black and I added hardener
I would recommend this over POR15 which I have used in the past because I have found the POR15 flakes away very easily after not too long. Just my experience.
ID:	20117   Click image for larger version
110, axle
110 salisbury rear axle tommyd Wanted 10 July 25th, 2009 09:39 AM
FS 110 Salisbury rear axle ECR For Sale - Parts 0 June 27th, 2008 01:08 PM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Salisbury Rear Axle for Sale Northface For Sale - Parts 1 August 12th, 2005 06:54 PM
