Restoration Time/ Advice. - Page 2 - Defender Source
Old June 28th, 2013, 02:35 PM
RickM
Rick Mabus
95 D-90 ST
This is fantastic info on the flares. I am going to do a bunch of work to my truck this weekend, so I will report back.
I might even try this on the grill.
Old June 28th, 2013, 04:24 PM
Your AC compressor is faulty .... probably a bearing failure or something.
Get it replaced.
Old June 28th, 2013, 11:25 PM
RickM
Rick Mabus
95 D-90 ST
I ill get the compressor looked at. Having some cold air blowing on me without totally robbing power would be excellent in this heat.
I took some compound to my hood this afternoon and the news is not great, but could be worse. I do think this truck had some initial body work done, and I think some cc was used. I will take pics tomorrow. I also picked up the necessary wheel flare supplies
are the rear flairs held in with the plastic rivet thingy's? I know the front are screwed in but the rears look like they are plastic snap rivets.
I will get pics up tomorrow.
Old June 28th, 2013, 11:42 PM
They are held in with plastic rivets. They are a PITA to remove without destroying them.
Starts at 6:28 in the video:
Old June 29th, 2013, 03:08 PM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
I have a AA yellow truck as well. I'm getting some touch up paint prepped at the body shop and after looking up the paint code online I can confirm that the 95 yellow does have a clear coat.
Old June 29th, 2013, 06:01 PM
RickM
Rick Mabus
95 D-90 ST
That is extremely helpful, Regarding the technical info. I think it is time to take this to my local paint and body guys and see what they can do. My logic is that I will happily repair my fender flairs. If I screw up, I am out what I had planned anyway. Clear coat failure, and my failure sounds to expensive.
Old June 29th, 2013, 06:31 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
One of my favorite mods was from Safari HP that had a metal replacement cowl for the instrument cluster that replaces the plastic one that is almost always broken (or soon to break). Not sure if they are still making them, but I love that it was available when he made the run. Maybe check his site at safarihp.com
Old June 29th, 2013, 11:52 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Do you remember who made it Davis?
Old June 30th, 2013, 12:34 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Glad it was helpful. Remember to give the fenders a good key before painting them. Also, be sure to paint when the temperature is cooler otherwise you risk it coming out duller.
Old June 30th, 2013, 11:59 AM
RickM
Rick Mabus
95 D-90 ST
I decided to postpone the fenders until this 4th of july week.
Hare are some after pics of the hood. Hard to tell, but it is for sure better, but still showing problems signs.
The fenders showing damage "before"
The inside which is rough.
The dash.
The steering wheel.
The door panels.
advice, restoration
Time Question GYM Support & Suggestions 7 March 1st, 2008 10:36 AM
Vibration location! Advice please.. EdF Defender Technical Discussions 11 January 1st, 2006 05:29 PM
Advice Sought... cbass Misc. Chit-Chat 29 March 11th, 2005 07:56 PM
Inconsistent post time bd90 Support & Suggestions 4 December 19th, 2003 08:34 AM
Time Mike Hippert Support & Suggestions 3 October 1st, 2003 09:30 PM
