Restarting after storage (diesel) - Defender Source
Old August 1st, 2015, 11:18 AM
Matt_110's Avatar
Matt_110
Matt
110
I'll finally be bringing my 110 out of storage after clearing out some space at home. It's been in your typical storage unit with little to no humidity (North Texas) and it's been over a year since the engine has turned over. It had about 1/4 tank of diesel and the tank is a new metal unit. It has a 2.8TGV with less than 500 miles on it so I want to make sure I don't cause any unnecessary damage by brining it back to life. Is there anything I should do prior to starting it up again? It will be getting a new battery since the old one went TU. should I summon a witch doctor? Sacrifice a beagle? Thanks in advance.
1987 110, 2.8TGV, ZF Auto
Old August 1st, 2015, 01:11 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Just start it. It's a Diesel. Diesel doesn't go bad like gas
You know how many machines sit for years without use and then get started up and put right to work?
Obviously check oil level and such first but it's no biggy
Old August 1st, 2015, 01:13 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I would top it off with fresh diesel in case you had a little condensation build up, install a new filter then fire it up.
Old August 1st, 2015, 01:39 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
New fuel filter, new diesel (might had some atf). Put your new battery on and crank it. Let it idle for a couple of minutes and take it for a spin. I would change the oil after that.
Old August 1st, 2015, 02:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by bossman429 View Post
Just start it. It's a Diesel. Diesel doesn't go bad like gas You know how many machines sit for years without use and then get started up and put right to work? Obviously check oil level and such first but it's no biggy
I love how on TV shows or movies they show someone popping in a battery in a gasser and then the vehicle comes right to life after sitting for a long time.
The battery went TU? The only thing I can think that means is Tits Up - and I haven't heard that phrase for a lot of years.
Old August 1st, 2015, 02:25 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Totally Useless
RDavisinVA
Old August 1st, 2015, 03:14 PM
Matt_110's Avatar
Matt_110
Matt
110
Tits Up or Tango Uniform. 20 years in the military is hard to shake off.
I've watched one of those Alaska discovery shows (take your pick), where they started an old generator after 30+ years. I just wanted to make sure I didn't harm the motor since it's just broken in. Thanks for the replies....I'll fire it up!
Old August 1st, 2015, 03:49 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Haha love that phrase - heard it from a farm boy Vermonter when I was up in college. Good luck starting it up.
Old August 1st, 2015, 07:40 PM
Chowbird's Avatar
Chowbird
Tim
'84 D90
This thread is cracking me up. Throw the beagle in the back,let the witch doctor ride shotgun, fire it up, and let us know how it goes
Old August 1st, 2015, 07:44 PM
We need a video of the start up....
Old August 15th, 2015, 03:09 PM
Matt_110's Avatar
Matt_110
Matt
110
Well, it started up like I drove it yesterday. Winner winner chicken dinner. I deeply apologize about the long ignition turn. I guess I wanted to make sure the plugs were warm. Hopefully this link works....never used YouTube before. Enjoy this boring vid. https://youtu.be/MwEVJERTUl4
Old August 15th, 2015, 04:11 PM
Wow, very nice...dig the color and the exhaust exit setup!
Old August 15th, 2015, 05:06 PM
Rear passengers need one of this caution hot exhaust signs!
Old August 15th, 2015, 07:35 PM
Matt_110's Avatar
Matt_110
Matt
110
Thanks Nathan. In its previous life it was fitted with a 3.5 and ran around Luton, UK. It had the exhaust exiting there. When I fitted the 2.8, I made sure to run the TDI exhaust to the same exit. I had to give Richards Chassis a template so when they made the chassis, they put a hole in it and strengthened the "box." I like it. But yeah, watch your legs passengers!
Old August 15th, 2015, 08:22 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Lucky. A lot of fungus and bacteria can grow in diesel in a year under the right conditions. Or did you dose it with biocide before storing it?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 15th, 2015, 08:40 PM
Matt_110's Avatar
Matt_110
Matt
110
I should have, but no. I may put some in now that it's at the house. I still have a lot of work to do to get it on the road.
Old August 15th, 2015, 10:01 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
X2.....been there....done that....not good...
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old August 16th, 2015, 07:25 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Make sure you have a spare fuel filter on hand then. There's a good chance it will clog quickly.
I don't know if biocide dissolves existing fungus (the product info should say), but yes, add some.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 16th, 2015, 08:22 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
White paste = infected fuel.
You'll see it in the top of the filter or in the bottom of the sedimenter.
Our son got an infected batch of fuel in NY that nearly filled the sedimenter up with water and white paste.
Luckily after the first filter clogged and had to be replaced, the dead algae didn't make it to the fuel filter because he pulled over and drained the sedimenter every 20 miles for about 100 miles and after that the sedimenter was pretty much clear.
RDavisinVA
Old August 16th, 2015, 10:05 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Ouch.... Never heard of this before! Sounds bad!
MonLand
1995 D90 NAS
1996 Discovery NAS
Restarting after 3+ years of sitting wcampbel@nas.edu Defender Technical Discussions 5 May 26th, 2015 11:52 AM
2.5 NA diesel - Fuel won't pump after changing fuel filter Ruedelesseps Defender Technical Discussions 3 January 10th, 2015 09:10 PM
S3 Diesel 2.25, won't start after pump re-seal jgrear Series Technical Discussions 14 August 17th, 2014 05:16 PM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
