Restarting after 3+ years of sitting - Defender Source
Old May 21st, 2015, 03:47 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I am disgraced to admit this, but my 1994 D90 NAS redo became a project which I neglected (Life happens). Anyways I am back on the ball and she is close to being ready to crank. It has been garage kept the entire time, but what should be my main concerns upon restart attempts? I would guess getting oil to the engine is number one (worried about the oil pump being primed) but after that what else should I be looking at upon crank?
Below is a list of all the things I did when she was down in case you want to review for an idea of what I have been into:
- removed AC
- replaced thermostat
- new exhaust
- oil change
- new engine mounts
- hot tanked oil pickup, oil pan and that small part of crank housing
- did the cross seals
- fuel filter upgrade kit
- new metal dash frame
- all new VDO gauges including speedometer and matching sender(s)
- new exmoor interior
- badger top
- Corbeau seats
- rear speaker boxes
Any suggestions, ideas, etc. are greatly appreciated.
Bill
Old May 21st, 2015, 04:52 PM
Remove the plugs. Crank it over without them and check the oil comes up to pressure.
Old May 21st, 2015, 05:40 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Gracias. Gonna go look up the pump threads.
Old May 21st, 2015, 06:32 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Radiator flush, check brake and fuel lines, fuel pump & all rubber hoses...
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old May 22nd, 2015, 06:19 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Ha fuel been in the lines to the rail? If so I would purge the old gas out as well.
Old May 26th, 2015, 11:52 AM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I dumped a bunch of fuel when I did the filter upgrade kit. I may pump out the tank anyways and refill it. I am still a few weekends away from cranking it up, but I wanted to get all the info I could before trying to start it.
B
start, starting
Sitting at work JBurt Misc. Chit-Chat 104 December 23rd, 2016 08:13 PM
LR ending Defender production after 67 years apierce Misc. Chit-Chat 2 October 17th, 2013 04:45 PM
After 26 years of dreaming.... Gunmaker Defender Technical Discussions 14 September 5th, 2009 11:25 AM
Sitting D-90 mikeybob2@msn.com Defender Technical Discussions 8 March 23rd, 2008 06:48 PM
Sitting Level - OME & ARB Bull Bar w/ Warn Winch TurkD90 Defender Technical Discussions 23 January 5th, 2005 10:44 AM
