Reskinning a door - Defender Source
Old September 23rd, 2009, 10:34 PM
ORover's Avatar
ORover
Fred
NAS 110s #24 and #466
Reskinning a door
My drivers' door has some bad dents that can't be straightened. Anyone here try and reskin one? What tools are needed and should I get the galvanized skin? Any tips? Thanks!
Old September 27th, 2009, 11:40 AM
I recommend a copy of the Haynes restoration manual ... has step by step advice for reskinning a door including photos.
http://www.amazon.com/Rover-Defender...4065623&sr=8-4
The suppliers mentioned in the book don't seem to be around anymore but I really like the idea of the plastic coated door frame to prevent future reactions between the skin and frame.
Old September 27th, 2009, 09:02 PM
ORover's Avatar
ORover
Fred
Thanks! Just bought the manual.
Old September 27th, 2009, 10:56 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
What years of defenders is that manual for?
Kris
Old September 28th, 2009, 08:15 AM
It is not year specific - just Defenders in general.
Old September 28th, 2009, 09:12 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
best done with the right tools
http://www.eastwood.com/autobody/pan...installer.html
and much patience.
I do it for new doors were I've galvanized the frames but other than that generally would use an entire new door unless the frames were in as new condition. Once you stretch the skin it is very difficult to get it back.
Matt Browne
Old September 28th, 2009, 09:13 PM
So a 2x4 and a hammer is not the proper tool?
Old September 28th, 2009, 10:02 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
listen, there is not such a thing as a galvy door skin
Old September 28th, 2009, 10:43 PM
There is since 2008.
Ron
Old September 28th, 2009, 10:58 PM
OEM I think yes, they're using some sort of corrosion-proofed door now. Not sure that there are any aftermarket replacement skins that are galv'ed, never seen any.
Old September 29th, 2009, 07:00 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
depends of your definition of proper. I have a feeling that YOU would make it work!
I'm not a big fan of the new "corrosion proof(?)" doors. I'll bet that they still corrode between the layers. I don't know why Rover didn't just galvanize the frames and leave the alloy skin, which works really well as there is little electrolytic reaction between zinc and aluminum especially if one or both are painted. Ever look a SI doors. They are built this way. I have several that have survived being in Maine since the late 50's and still look great.......as far a corrosion is concerned
Matt Browne
Old September 29th, 2009, 08:24 AM
For Ron good it is!
Old September 29th, 2009, 08:35 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
If you are doing a couple doors it likely doesn't pay to buy the right tools, but here is the right tool that we use:
http://www.killertools.com/
There is no body work needed after install and the job takes about 80% less time than other methods, and potential damage to the door skin is not really possible. I don't know any body guys that use the door skin pliers or the roller type anymore, those went away years ago.
It may seem costly, but it will save you its cost in time spent.
Email:
Old September 29th, 2009, 11:13 AM
crown14's Avatar
crown14
Verticalscrote
Ron
The electroplated zinc phosphate coating should not be confused with the hot dip galvanizing.
Anyhow, the 2007 doors in my garage have the EZ on them, so I think it started a little before 2008.
Old September 29th, 2009, 03:48 PM
Fair enough, I have only seen them advertised as 2008. Safari rover had some skins only for sale in the bright zinc coating. If you hot dipped a door skin it would come out in waves.
Old September 29th, 2009, 05:13 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Along with most of the guys that knew how to work metal by hand. Kind of sad.
I was taught to use a hammer and dolly, by hand......mostly do it with an air hammer (and dolly) now so as to move along with the times, Still use pliers in the tight spots. Just a fawkin dinosaur waiting for the next ice age
Matt Browne
Old September 29th, 2009, 06:55 PM
ECR's Avatar
ECR
Better tools that reduce customer's cost, do a better job and require less bodywork for the body guys (less customer cost there as well) don't translate into any loss of skills IMO.
30 years ago I did it by hand as well, but not today.
I gave up my old Apple IIE computer as well... better stuff came along.
Email:
Old September 29th, 2009, 08:56 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Wasn't trying to say that you don't have mad skill homes. That's fairly obvious to even the mildy observant dinosaur.
30 yrs ago......what was that , high school shop?
Matt Browne
Old September 29th, 2009, 10:56 PM
ECR's Avatar
ECR
30 years ago was doing the same thing I do now, just smaller scale and on different makes, had my own detail/small repair business at the time. Never took high school shop, making picture frames was never my thing.
Email:
Old September 30th, 2009, 07:21 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
oops....sorry, I had no idea you were that old...
Shop was a required class back in the dark ages. Never did make a picture frame. Did build a redneck tractor (Model A) and a pretty good collection of "peace" pipes, in addition to a pretty good base knowledge of mechanics and metalworking. They had a good program perhaps due to the large amount of Defense $$ in the area (PNSY, Pease AFB, Pratt & Whitney). Still a huge depth of talent in the area with old duffs that can pound out the most complex bits, by hand, in no time at all (a talent I often employ). That's the sort of talent I'd be referring to as being lost. The artist. Granted most of this can be created by geeks with a computer and some drooler running a machine.....the new artists......so here is not much point in my reminiscent rambling, other than I suppose you can, with patience, skin a door with a hammer, dolly (or 2x4 Ron) and a pair of pliers.
But if the guy with the coolest tools wins....you got it, hands down .
Matt Browne
door
sw door parts Abrooks Wanted 0 February 15th, 2006 08:28 PM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
SW Rear Door Rattle seattlejanzen Defender Technical Discussions 5 November 5th, 2003 10:25 AM
