Resetting CHECK ENGINE light '95 NAS 90 SW - Defender Source
Old May 29th, 2015, 06:15 PM
ymc226
Lawrence
1995 D90 SW NAS
I took my truck into a local mechanic that works on all sorts of cars including classic ones as my engine was making a clacking/tapping sound at idle that increased in speed when I stepped on the gas but soon disappeared. I've lived with it for a while but a gas station attendant thought it could be a rod or something coming loose and suggested I have it looked at.
Normally I would take it into the local LR dealer (Princeton) but the only mechanic versed in Defenders isn't there anymore. Anyway, my local guy removed the valve covers and intake plenum and removed/cleaned the rocker arms and oil passages and noticed no unusual wear that would be detrimental to continued use. He halfway suggested that I could replace the lifters for about $1000 but that would not guarantee solving the noise issue.
I was charged $311 and it still makes the same noise but if I can drive it knowing that nothing bad is going to happen, I'll live with it.
However, now my check engine light is on. I'm thinking he didn't reset it when he opened up the engine. Is there a way for me to reset it or let me know how to let him do this since I don't think he knows Rovers well. I just checked and it is an error 17 code that lights up.
Old May 29th, 2015, 07:09 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Code 17=Throttle Potentiometer
Yes, you can reset the light.
Land Rover On Board Diagnostics Codes - Pangaea Expeditions
"Once the problem is resolved, you can clear the code simply by disconnecting the vehicle battery for 30 seconds. If the check engine light returns, you will know that the mechanical problem is continuing to occur."
^^ I always liked their write-up ^^
Rent my
Old May 29th, 2015, 08:24 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks Jeff,
That did it. Now going to install Jason's interior door handles and vents.
Regards,
Lawrence
90, 95, check engine light, engine, ht, nas
Used ScanGaugeII fpr resetting ODBII codes GaryBaxter For Sale - Parts 1 November 8th, 2014 05:15 AM
Check Engine Light On david_jackson Defender Technical Discussions 18 October 11th, 2004 03:49 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
