resealing roof? - Defender Source
Old March 14th, 2012, 10:10 PM
tommyd's Avatar
tommyd
Tom
LR3
resealing roof?
Is there a thread somewhere on resealing a 110 roof? Judging by the water stains on my headliner, mine leaks above the front doors and to a lesser extent in the back corners too. Haven't dropped the headliner to have a closer look. Interested in hearing any tips, tricks, parts I need, etc. Thanks.
Tom
Old March 14th, 2012, 10:30 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Do you have a sun roof ?
Old March 15th, 2012, 06:57 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If the leaks in the front are at the forward corners it could be the door gasket seal. The way the top and windshield attach there is a small gap which is usually filled with caulk. The way the rain gutter is made and attaches I would look for any cracks in it or where it is attached. As mentioned by Dennis the sunroof can leak and also look at the Alpine windows.
Land Rover 110
Old March 15th, 2012, 07:51 AM
tommyd's Avatar
tommyd
Tom
LR3
No sunroof, and doesn't look like the alpine windows are leaking. I'll check the door gasket seal. Would silicone be better than caulk to fill the gap? Seems like it would be more flexible once dry. Thanks.
Old March 15th, 2012, 08:10 AM
Tom:
I used this stuff called "strip caulk" when I did mine, available at any auto body shop and permanently flexible. Another option would be duct seal, available at any Home Depot.
Old March 15th, 2012, 08:45 AM
Xcelsius
Matt
89 D110
Try the Defender Water Ingress Manual for common areas of entry.
http://www.scribd.com/doc/17833628/water-ingress-manual
Old March 15th, 2012, 12:34 PM
pendy's Avatar
pendy
jim pendleton
89'd90
This sounds like the problem to me also. I use Body seam sealer in white by 3M But the color of your truck, you may be happy with black. Heck even right stuff may look alright in that cavity for you. Be sure to clean the area and dig out all old sealing material real well before sealing..
legend in my own mind
Old March 15th, 2012, 09:26 PM
Capt Milks's Avatar
Capt Milks
Just about anything will work as long as it stays flexible and can be removed. I have uses the strip caulk found at Lowes or Home Depot but the Auto Paint store has the best stuff.
Land Rover 110
Old March 16th, 2012, 10:02 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
Is there another file that isnt attached to facebook?
roof
Hannibal Roof Top Tent for Sale - 1.2m NomaD110 For Sale - Parts 8 January 17th, 2012 11:46 PM
Resealing SW roof gutters and seams dave_lucas Defender Technical Discussions 7 June 10th, 2009 06:41 PM
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
Humor the ST aluminum roof dream... thecatsmeow Defender Technical Discussions 30 October 5th, 2004 08:31 PM
No roof! jamesmorfee Defender Technical Discussions 3 March 5th, 2004 09:24 AM
