Reseal Transfer Box - Defender Source
Old July 30th, 2012, 05:53 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Reseal Transfer Box
Just resealed the transfer box with Really Right Stuff... how long should I wait before filling it back up with oil?
Old July 30th, 2012, 09:56 PM
I wish you'd actually deal with the leaks rather than cover them up.
Any idea what that stuff does to all the bearings and gears?
Old July 30th, 2012, 10:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
What are you talking about? Right Stuff is a gasket maker used for things like the access plate.
Old July 31st, 2012, 12:02 AM
aaronlam's Avatar
aaronlam
aaron lam
My truck's got nothing but gorilla tape and rust holding it together!
This is what I did... just for future reference and some tips that I learned.
1. Remove fill cap... I used a 1/2 socket driver... a bit hard to get to but an extension will help you get away from the brake drum. Remove drain plug and drain.
2. Remove the 10 bolts to the transfer plate (10mm). 3 are behind the y-pipes and hard to reach without dropping the pipes but doable (this references a 97). A ratcheting wrench and universal joint was helpful. Surprisingly, something so drenched with oil was still hard to get off... it needed a couple coats of PB Blaster to coax it.
3. I used a putty knife and lightly tapped it in between the plate and the transfer case. Popped off after that.
4. Cleaned the prior Right Stuff gasket off with a razor carefully... I used a window scraper thingy to keep it flat. The plate has a line down the middle of the outer edge (I presume to cause more of a seal) so you have to do each side separately. I wiped some more with a little goo gone and then degreaser... left to dry.
5. Probably could have gotten new bolts as mine has some deposits in the thread... also left over Right Stuff on the bolts. I used a nut and wire brush to clean the threads and made sure they went on smooth by hand. Applied hylomar to the threads.
6. Lined the cover plate (right on that line) and around the bolt holes with Right Stuff gasket maker like icing on a cake.
7. Carefully put back on.
8. Let dry for SIX HOURS!!!
9. Hylomar'd the drain plug and fill cap and put back on. Filled with Royal Purple 75w90. I needed a hand pump to get it in there and used about 2.25 qts. I was careful not to spill that expensive stuff.
Hopefully that was all right!!! I guess we'll see tomorrow when I drive around. I'll let you know if it leaks again. Let me know if I did something wrong.
ID:	54913   Click image for larger version
ID:	54915   Click image for larger version
ID:	54917   Click image for larger version
Name:	D90-Workshop Manual.jpg
Old July 31st, 2012, 08:43 AM
Naplm00
Matthew
Very thorough post. I used permatex black RTV with the same results
Old July 31st, 2012, 09:39 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Lets us know if your leak free. I've got the same leak and hoping a reseal of the inspection plate does the trick.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old July 31st, 2012, 04:15 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Awesome right up. I hope it works. Guys that saw these things new said they weeped oil when they came off the truck....
Old July 31st, 2012, 04:38 PM
aaronlam's Avatar
aaronlam
aaron lam
I've heard that too. All I have to say is: YAY!
Old August 1st, 2012, 11:22 PM
Nice post. I resealed my inspection plate last month on the 110, did exactly what you posted essentially. Good news is the inspection plate hasn't leaked since. Bad news is it made me realize the leak was actually coming from what I believe to be the intermediate shaft in the tcase.
Old August 1st, 2012, 11:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Great write up!
Looking at your photo with the arrows makes me think my weeping leak also might be the inspection plate. I have always thought it was front or rear input seals because someone mentioned that as common. I just changed the oil but come next change i'm going to put a new gasket on and see if the leak stops. Thanks for the tip!
Old August 8th, 2012, 11:28 PM
aaronlam's Avatar
aaronlam
aaron lam
So 150 mi... a little off road running through low and high gears... there is a little bit of a weep from that one bottom bolt. Oh well. It's 100x times better than before and nothing dripping on the ground anymore but when I touch that bolt, it's wet.
If anyone figures out how to seal the transfer box better... would love to hear!
Old August 9th, 2012, 12:18 AM
aaronlam's Avatar
aaronlam
aaron lam
No... this bolt... it's just this one bolt.
Old August 9th, 2012, 12:32 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Is your breather clear?
1970 SIIA 88, Sold
Old August 9th, 2012, 12:37 AM
aaronlam's Avatar
aaronlam
aaron lam
errr. Not sure. How do you know or check?
Old August 9th, 2012, 12:52 AM
aaronlam's Avatar
aaronlam
aaron lam
Reseal the shank of that bolt with 'the right stuff'
-Jeff
Next drain. There's $50 worth of Royal Purple in there!!
1.4 transfer box..feeler.. the rover shop For Sale - Parts 1 July 19th, 2012 07:28 PM
Who's done a reseal kit in a PS box? Hans Defender Technical Discussions 1 July 5th, 2010 09:12 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
