Report of ride height & ground clearance gains after mods - Defender Source
Old June 6th, 2014, 04:33 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
I did a lot of research on this site when I was researching tire and suspension options. As such, I am posting some raw data from mods here for posterity in the hopes someone else finds it in a search. If you have similar data, please post up for others.
Truck: 1986 110 SW 2.5 NA
'Stock' with standard springs & 235/85R16 tires
Rear X member lowest point: 52 cm
Middle of slider: 53 cm
Middle of frame: 35 cm
Front bumper, lowest point: 46 cm
Front diff : 25 cm
rear diff : 24 cm
'Stock' with standard springs and 255/85r16 BFG Km2 tires
Rear bumper: 55 cm
Middle slider: 56 cm
Middle frame: 40 cm
Front bumper: 50 cm
Front diff: 27 cm
Stock with OME HD front, MD rear and the Km2s
Rear bump 58cm
Middle slider 58cm
Front bumper 52cm
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old June 6th, 2014, 04:40 PM
ontheway's Avatar
ontheway
Dave
'Stock' tires and suspension
255/85r16 KM2s with stock suspension
255/85r16 KM2s with OME heavy duty fronts, medium duty rears
Old June 6th, 2014, 11:09 PM
i like those white wheels on the blue truck
Old June 7th, 2014, 09:59 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by ontheway View Post
'Stock' tires and suspension 255/85r16 KM2s with stock suspension 255/85r16 KM2s with OME heavy duty fronts, medium duty rears
Has the 2.5na drive performance dropped significantly around town with the 255's? I assume you have a 1.6 tc. Really like the stance your truck has. Looks great.
Clay
Old June 7th, 2014, 10:30 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Funny timing with this thread as the end result leads to text exchanges like this one last night.
Old June 7th, 2014, 11:51 AM
ontheway's Avatar
ontheway
Dave
Originally Posted by 1of40 View Post
Has the 2.5na drive performance dropped significantly around town with the 255's? I assume you have a 1.6 tc. Really like the stance your truck has. Looks great. Clay
Thanks! I have not noticed performance drop with the tires... But significant issues with all the weight of the cage and ARB. Hence the upcoming OM617 upgrade!
Valve clearance after head work? UnfrozenCaveman Defender Technical Discussions 9 August 13th, 2013 10:26 AM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
lift, droop and tire size, ground clearance... wantone Defender Technical Discussions 17 October 21st, 2011 02:45 PM
Ride Height Measurement Wolf Fabrication Defender Technical Discussions 7 July 24th, 2010 09:58 PM
Freebie! Instant HP gains! 007 The Vendors Loft 0 May 21st, 2009 01:24 PM
