replacment starter for V8 110 - Defender Source
Old January 15th, 2014, 12:12 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Need a quick replacement starter motor for an 1985 V8 110 pretty sure they are all the same ( Rover V8's) just not positive have not replaced one in years. Any one know of a source ? It's in Hamden CT USA or is there a cross reference to other starters that will fit ?
Thanks in advance
Chris "V"
Chris "V"
Old January 15th, 2014, 12:56 PM
Thanks in advance
Chris "V"
all defender, disco, classic etc V8 starters supercede to the same number.
Old January 15th, 2014, 01:37 PM
Chris Velardi
Chris Velardi
1975 101FC
excellent, thanks very much, that is what I thought . I was able to order one rebuilt at a shop in West Haven CT called UPE Unit Part Exchange for $90.
Chris "V"
Old January 15th, 2014, 02:03 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Paul Grant is up in CT.
He is probably tripping over used starters available for reasonable prices...
Rent my
Old January 15th, 2014, 02:21 PM
Chris Velardi
Chris Velardi
1975 101FC
Don't know Paul what part of CT is he in ?
Chris "V"
Old January 15th, 2014, 02:33 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
His profile says he's in New Milford, CT.
Paul Grant
203-770-1699
paulgrant@mac.com
He usually has lots of V8 stuff around-Disco 1 & 2, Range Rover parts
http://www.defendersource.com/forum/members/paul+grant-1421.html
Rent my
Old January 15th, 2014, 02:36 PM
LRover's Avatar
LRover
J. Michael McCaig
Early V8 Defenders with a ballast resistor in the ignition circuit had an extra terminal on the starter solinoid. The purpose of this is to send full 12v to the coil during cranking and 6v while running. I bought a "generic" new starter for my '85 110 and found out the hard way that this extra terminal was needed for my truck as it would only run while cranking. Luckly the solinoid on the new starter had the connection for the run terminal but it had just been cut off during assembly at the factory. I was able to solder on a replacement spade terminal and was good to go. Moral of the story is if you have a ballast resistor, make sure your new starter has the connection needed (or replace the coil, rewire etc).
Old January 15th, 2014, 03:35 PM
Mike you are still running points ?
Old January 15th, 2014, 04:04 PM
Chris Velardi
Chris Velardi
1975 101FC
this is what my old one looks like . a few large cables going to the lug on the right and one small blue wire going to the spade on the bottom
Name:	starter solinoid.jpg
Chris "V"
Old January 15th, 2014, 07:08 PM
LRover's Avatar
LRover
J. Michael McCaig
Chris it looks like to me that you should be able to use the later style with no problem. The small brass knob in the top of your photo is where the second terminal is on my starter.
Doug I'm running a rebuilt points distributor that has been converted to electronic ignition, Petronix if I remember right. Has been trouble free...uh oh...now I've done it!
Old January 21st, 2014, 10:47 AM
Chris Velardi
Chris Velardi
1975 101FC
Ok got the replacement starter and fist notice the top hole was threaded ( figure if it would brake my stones I would drill it flat ( like the stock Lucas unit) then I notice the bolt holes were larger than I remember the stock ones being.( figured easier to line up bolts... So went out in the cold dark night ( snow storm coming in today at noon) and I could not get the starter to seat properly like an 1/8 " from seating flush against the housing . anyone else run into this . It is supposed to be a bosh starter the old one was a lucas but I thought they were all universal
Name:	sarter new bosh.jpg
Chris "V"
110, ac, start, starter, v8
Starter Problems Trigger Defender Technical Discussions 10 September 27th, 2006 10:00 AM
110 Rock Sliders tobit3 For Sale - Parts 4 March 24th, 2005 05:17 PM
Starter going bad? loykd Defender Technical Discussions 6 September 15th, 2004 10:12 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
Defender 110 and 90 tool kit mpodgorski For Sale - Parts 5 May 4th, 2004 09:17 PM
