replacment 120 + alternator - Defender Source
Old August 26th, 2013, 11:30 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
trying to find a 120 + alternator that will bolt in to a 1987 110 v8.
Chris "V"
Old August 26th, 2013, 11:41 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
You tried any of the hotrod or custom car websites ?
Old August 26th, 2013, 12:23 PM
Chris Velardi
Chris Velardi
1975 101FC
not yet tried the hot rod shops , id like to retain the stock bracket ,not sure what others have found to fit . have read about a VW 120 unit but it shows a bunch of dead links ... no part #s
Chris "V"
Old August 26th, 2013, 12:26 PM
scrubs
henery
1974
find a local rebuild shop & have it rebuilt internally
Old August 26th, 2013, 12:31 PM
Chris Velardi
Chris Velardi
1975 101FC
dropped it off on Friday just not sure if they can up the output from 65 to 120
Chris "V"
Old August 26th, 2013, 12:41 PM
120 amps will need a double pulley or serp belt
Old August 26th, 2013, 07:26 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Try Wrangler Power Products?
Hmmm, not sure how much difference there is between the V8 in you '87 and the NAS Defenders, but Wrangler Power Products did carry 120,160 and I believe 180 A small case alternators that would fit the NAS Defenders.
Not sure about the belt situation, but I had a 160A small case alternator from North West Power Products on on older Pathfinder, and it was driven by a single v belt without issue. And yes, even at full draw (it would put out about 110 A at engine idle speed per the mechanics load tester that didn't believe it could till he saw it)..
Catalog..
Looks like the have a 150 Amp Alternator (105 a at idle)
150 AMP -- 1993-97 LAND ROVER, DEFENDER
This Wrangler NW Power Product High Output Alternator Kit has a rated output of 150 amps. Idle output is rated at 105 amps.
Features dual fans for superior cooling. Internally Regulated Alternator Kit (shown) P/N: 200-700
~Scott T.
'95 D-90 ST - AA Yellow
Old August 27th, 2013, 01:29 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Side comment: ask an alternator guy if he could up the stock v8 3.9L marelli and he said no.
MonLand
1995 D90 NAS
1996 Discovery NAS
ac, alternator
120 amp Rebuilt Alternator 97 Defender RoverDude For Sale - Parts 0 December 17th, 2009 01:57 PM
MG Alternator and Starter Qs Hollywood Defender Technical Discussions 2 April 17th, 2005 06:31 AM
Alternator wiring tmore Defender Technical Discussions 5 April 11th, 2005 06:17 PM
Help With Alternator for a 97 UpnOver Defender Technical Discussions 5 March 20th, 2005 09:43 PM
Alternator Abrooks Defender Technical Discussions 8 March 15th, 2005 10:59 AM
» Defender Registry
Sold
Bobby
curry
Add your Defender
