Replacing water Pump - Any Easy way to do it? - Defender Source
Old January 27th, 2014, 07:53 PM
so my water pump shaft has some play in it (1/4" when not running and it does have some wobble when running but not a lot, i believe this is due to the belt being properly tightened, my pwr steering belt is loose and was what prompted me to dig in to it) and i'm replacing it while I'm doing the belts
it looks pretty tight in there to get everything out. Do i need to pull the radiator and the front fascia? (which also means the ARB and the winch etc) or can i do it from above without pulling that stuff?
Any advice would be helpful - water pump is already on the way and i'm hoping to do it this weekend if everything works out with the parts arriving from AB.
95' D90 - daily driver..
Old January 27th, 2014, 08:02 PM
No you don't need to pull the radiator. My only tip would be to take a piece of cardboard and, using the new gasket, trace out the shape of the water pump and holes. When you remove a bolt, put it in the corresponding hole in the cardboard. This will help with reassembly since all of the bolts are different lengths.
Old January 27th, 2014, 08:05 PM
But some cardboard or thin ply between your work space and the rad ... In case your hand slips ... You don't want to hit the rad unnecessarily.
Old January 27th, 2014, 08:11 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Buy the autozone one with lifetime warranty. And don't over tighten the bolts.
Robert Deniro
Old January 27th, 2014, 09:17 PM
Yes, definitely do this. This is something I do on all cars when working on the front of the engine.
Old January 27th, 2014, 09:47 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Robert i have the wrench for the fan if you need it. Its a pretty straightforward job.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old January 27th, 2014, 09:52 PM
Buy genuine. Aftermarket are crap IME. I pull the rad because it is not that hard to do and gives more space. If I had oil cooler lines I would leave it in place with cardboard as noted above. Now is the time to do belts and hoses if they are at all suspect -- and a new fan clutch. Make sure you understand how to bleed it properly. Have new plastic plugs handy or replace with brass, those plastic bastards always seem to break or cross thread. Can clutch tool is very important, refit the fan clutch with antiseize on the threads to the snout.
Old January 28th, 2014, 12:59 AM
Brian i would like to borrow the fan tool.. (i ordered one from AB as well... since its something i'll need)
parts bought so far amount to the following
waterpump (AB STC483)
Hose Kit radiator (AB)
thermostate
clamp kit for hoses (dunno if i'll need it but .. it was cheap @ $10)
belt kit
gasket sealant (hydromar)
fan tool
my fan clutch is fine but worthwhile to changeout?
i have rave as well (which is great)..
i'm going to try and do it without pulling the Rad.. (since that means oil cooler lines, ARB, Winch, and a host of other bits)
Old January 28th, 2014, 07:56 AM
Id say take time the clean the RTV or whatever out of the threads in the block/front cover. IIRC it doesnt take much to seal it up. I am with Ron on this one, pony up for the genuine water pump.
Old January 28th, 2014, 08:47 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Robert,
Why would you need to pull the bumper to pull the Radiator? It comes out easy peasy. I pulled my and got it tested and recored when I did my water pump.
The fan clutch is simple enough to replace I would and keep the current as a spare. But I have spares for everything.
1995 Defender ST
1996 Discovery SE7
Old January 28th, 2014, 09:18 AM
frankly i've haven't done it before so ignorance on my part wrt pull the bumper. I may pull the radiator and leave the bumper in place for more room but we shall see.
current plan is to not pull the radiator and do it from the top.
Old January 28th, 2014, 09:21 AM
No need to remove the bumper.
I swapped an entire motor with the bumper in place.
Old January 28th, 2014, 09:30 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Robert,
I will tell you this, I started out with the radiator in place, and eventually said screw it. If you need a hand, I should be free this weekend.
1995 Defender ST
1996 Discovery SE7
Old January 28th, 2014, 09:49 AM
Thanks for that - and that is what i was thinking... since the system is drained might as well pull the Rad for clearance.
Old January 28th, 2014, 10:50 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
This may be a given assumption but do a good job removing the old gasket material from the front cover surface. It can be a pita if you aren't prepared to do it ahead of time.
Clay
Old January 28th, 2014, 05:13 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
What is a fan tool and what does it do?
Rent my
Old January 28th, 2014, 05:17 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
basically two wrenches. One for the nut and one kinda catches the studs to hold it in place.
1995 Defender ST
1996 Discovery SE7
Old January 28th, 2014, 05:27 PM
its a thin 32mm wrench that fits in the gap to undo the fan nut ....
Old January 28th, 2014, 05:53 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Oh....I've had my fans off numerous times and I don't have a fan tool; just a large crescent wrench.
The RRClassics dont need a fan tool.
Carry on...
Rent my
ac, water, water pump
Replacing my water pump Lindy Defender Technical Discussions 17 September 17th, 2013 11:23 PM
Water Pump Question Firemanshort Series Technical Discussions 19 December 26th, 2010 10:36 PM
300 tdi water pump housing pendy For Sale - Parts 0 February 3rd, 2009 09:17 PM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
