replacing the torx with hex - Defender Source
Old September 9th, 2012, 11:15 AM
doscazadores
Vic Stull
none
Any problem with replacing the torx that bolt down the roll cage components with hex? Will a socked fit the hex head in the space for the rear uprights that are tucked back in there somewhat? And it seems like copper anti-seize and a stainless bolt might be a good idea there?
Old September 9th, 2012, 12:16 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Room for hex?: no idea
Anti-seize?: absolutely
Stainless steel?: heck no. Check out the yield strength of different fasteners. There are several different grades of SS, which have different specs and none (that I am awre of) are equivalent to the 8.8 used on your cage.
1970 SIIA 88, Sold
Bill Larson's Avatar
Bill Larson
Bill Larson
Many good threads on this. Huge debate on the whole stainless bolt thing. Worth reading up on.
Old September 9th, 2012, 12:44 PM
doscazadores
Vic Stull
none
Thanks. I'll look around.
Old September 9th, 2012, 01:06 PM
61rover's Avatar
61rover
John Crouse
I found that the hex strip out easier than torx.
Old September 9th, 2012, 01:07 PM
I would take them out and clean them up or replace them with the same style. The hex do not look right on it, even black.
Old September 9th, 2012, 01:52 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I asked SD last week what they sold in terms of replacement bolts. I have an email where they sell steel or stainless steel. The stainless is A4 grade. I guess SS is an option, at least as far as safety devices is concerned. Its a SS button head with an allen socket.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old September 9th, 2012, 02:28 PM
A common stainless fastener that exceeds the performance of grade 8.8 is 17-7 PH Condition C.
17-7PH Condition A has a much lower yield strength.
Old September 9th, 2012, 02:34 PM
Reese_D90's Avatar
Reese_D90
Reese
Most SS that I could find are grade A2. The A4 are stronger. Do you know how that compares to your strengths listed above??
http://www.a2stainless.co.uk/M10-x-1...AHBP.aspx?nh=1
This seems to match in terms of higher strength and size but the length is too long if you like the torx look. This company would do a custom order for the right length if we could get 1,000 units.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old September 9th, 2012, 02:55 PM
Reese_D90's Avatar
Reese_D90
Reese
SD..........
"The bolts for the external part of your cage are both stainless and regular zinc plated steel, please see breakdown below:
All "saddle bracket" joints where tubes meet use M10 x 30mm Hex Head Zinc Plated bolts and each bolt requires 2 x M10 plain washers along with a M10 Nyloc Nut.
At the six points where the roll cage joins the body, we use M10 x 30mm Stainless Steel Button Head - each of these requires a M10 spring washer along with a M10 plain washer (both in stainless steel). The head of the bolt is an Allen head.
All of the above are readily available from hardware stores and would most likely be the most cost effective way for you to get replacements. If you want us to put a price together then we can although this would be more costly as you would have import duty to pay when it arrives in the US.
They are Allen socket, I believe that the size is 6mm.
I have attached a photo of the bolt for clarity."
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
ac
Replacing 4.0 with 4.6 Trevor Tarr Defender Technical Discussions 17 December 15th, 2004 10:21 PM
looking for advice on replacing the rear seat Doug Young Defender Technical Discussions 7 December 11th, 2004 05:40 PM
replacing sensors in manifold mattdh Defender Technical Discussions 3 September 20th, 2004 07:33 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
Torx Tool Matt Klapmust Defender Technical Discussions 8 June 2nd, 2004 11:27 PM
