Replacing the rear crossmember in a NAS 110, what do you do with the "saddle"
So on NAS 110 frames there is a "saddle" welded over the rear frame to reinforce it. ROW trucks don't have this. How do I weld on the new rear crossmember with this thing in the way? Do I grind off the welds and remove it, or do I cut the new rear crossmember so it fits around it?
I am planning to tackle this over the weekend so some help now would be appreciated.
I can't visualize what you're talking about. Let me go back to my room and post some pix of working on the rear x member of my 110. Maybe your answer will be readily apparent.
Which "saddle" are you referring to ? The lower anti sway-bar bar mount ? Quick work with a sawszall. Although I'm always looking for an excuse to buy a plasma cutter ;-)
When I get around to replacing the rear crossmember on the frame I got from you, I plan on grinding off the welds on the "saddle" or whatever you want to call that plate on top of the U portion of the frame. You are right, the ROW trucks don't have it but I guess it does add some strength...I haven't decided whether I will weld it back on.
We replaced the crossmember plus extensions all the way back to the spring perch, so it would have been tossed with the old x-member.
------ Follow up post added May 30th, 2010 07:19 PM ------
Yep, checked the pix. Saddle was there, we didn't replace it. Truck hasn't fallen apart yet. Actually, I guess Mike should chime in to verify that the truck hasn't fallen apart...
Ron, this doesn't look any different to the ROW frame. I have plenty of pictures of when I did Janey's rear crossmember. In my case I left them, although on one side it would have been better to have had longer extensions.
Charles, Janey does not appear to have had the saddle. If you look at the picture Jon posted it is the thing with the flat top under the mounts for the rear tub. This is NAS 110 specific. The problem is the replacement crossmember with extensions ends right in the middle of the saddle. If I had longer extensions (like JimC apparently did) I could cut the whole thing off, but I do not.
Oh I get it now, sorry. I did see it, but thought you were talking about the sway bar mounts.
If it were me I'd cut down the middle, and then fab up the missing half once the replacement cross member is in place. Doesn't look very complicated - 3 pieces of flat stock right?
Here are some pix that make it very clear where the saddle is at, and how much I replaced. I think if I were I, I would grind off the welds around the saddles, remove them, and then do the work. If I had noticed (and we had time), I would have welded on new ones to the crossmember we installed. I'm just anal like that.
Man I completely misread that question - yesterday was a long day. The brackets for mounting the nas bumper to a 110 are dead simple. I'll get you measurements but the only thing that matters are the diameter of the holes and the distance between them.
mmh, I'll have to think about this one. Fuel is the one thing I don't think I want in tanks under it, but maybe it would be useful as a waste water tank. BTW I'll be seeing Ren Ching before he heads up your way, so will give him your bumper goodies from Dmitry's bumper.
I don't have a picture handy but I think I posted one here once before. I'll take one sometime but here are the important dimensions: 3 3/4" center to center of the holes. one hole 3/8, the other 1/2. 1/4 thick strap - forgot to measure width but it's probably 2-3".
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
