Replacing the Parking Lamps and Lenses (how-to) - Defender Source
Old January 28th, 2009, 09:10 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
This was one of the better sub-$50 upgrades that I've done to my truck. Replaced the faded-out parking lamp lenses with fresh, dark, genuine parts lenses. Also replaced the incandescent bulbs with LEDs from superbrightleds.com
Parts used:
Qty. 4 Lens, Front Amber $5.91 each from Rovers North (would have bought from AB but they didn't have any)
Qty. 4 BA15 9-LED bulb, Amber, 67-A9 $2.99 each from superbrightleds.com
Install was easy. I had been having problems with the incandescents burning out but it turned out to be a weak contact on the receptacle. Pushed the receptacle tip in and bent the the little copper contact out and that cured this issue.
I can't believe how much better the truck looks. The old lenses were really faded out, almost clear, and that caused the lamps to appear white. (see first pic) The new LEDs are amber, so the lamp will still look decent even if the lenses fade again.
ID:	17544   Click image for larger version
ID:	17546   Click image for larger version
ID:	17550   Click image for larger version
Old January 28th, 2009, 11:12 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Definitely better than my fix, I had the faded lenses for a long time too..... but ended up just repainting mine with a clear orange model paint. Holding good so far, but the lenses are getting old and starting to crack at the lips.
You wouldn't have found a part number for the socket in your search, would you? One of mine needs replacing. I have a set of the newer style lenses/sockets laying around, but I'm too lazy to figure out how to swap them. Maybe when the weather warms up.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 29th, 2009, 01:47 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Nice job. Thanks for posting.
Old January 29th, 2009, 01:48 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Hey that looks great. I think I'll do that only with the new clear lenses.
Old January 29th, 2009, 02:08 PM
chris snell
Chris Snell
87 Ex-MOD 110
Which years had the two clear lenses?
Old January 29th, 2009, 08:54 PM
94 but I think they were amber, no NAS trucks have clear indicators I dont think..
Old January 29th, 2009, 09:25 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
No, but european ones have a clear lens on the top and an amber on the bottom I believe. That is what I put on my 110.
Old January 29th, 2009, 11:34 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I did all clear on my truck with yellow bulbs on the turning signals...
Legend in My Own Mind.
Old January 29th, 2009, 11:35 PM
cellulararrest
Chris Snyder
Randy do you have the smoked lenses off the new euro defenders? If so, you wouldn't have the part number would you?
Old January 29th, 2009, 11:56 PM
chris snell
Chris Snell
87 Ex-MOD 110
Yes, but you also have a silver-painted grill.
Old January 29th, 2009, 11:58 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I believe its called Brunell Grey as per land rover... I will be ordering some bulbs for sure. they are nice Chris.
Old January 30th, 2009, 10:06 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Chris did you find any LEDs for the rear lights?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old January 30th, 2009, 05:27 PM
chris snell
Chris Snell
87 Ex-MOD 110
There are LED options, definitely. Do you have square lights?
Here's what I went by:
http://www.defendersource.com/forum/...0&postcount=14
Personally, I think I'm going to hold off on converting the rear bulbs. The LEDs definitely look different. In the conic-shaped lens of the parking lamp, it's not very noticeable. With the flat rear lenses, however, I think that you would see the individual LEDs.
Old January 31st, 2009, 01:52 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I bought all but the turn signals from there and didn't spend much on them. So far they have been pretty nice. Only complaint is with the back up light. For me LEDs aren't bright enough to see very far.
Jimmy Buffett
ac, lamp
