Replacing split column stalk gaiters? - Defender Source
Old November 16th, 2008, 10:21 AM
turbodave
Dave C
1983 110
Are these available / rebuildable? I pulled apart my horn stalk and it looked like the rubber gaiter is not easilly changed. Both the indicator and windsheild are split and look ugly and if its easy, I'd like to change them.
Thoughts?
Old November 17th, 2008, 01:26 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
HI Dave,
The gaitors are not available seperately however they can be glued with a good rubber glue and then the gaitor turned around so the glue line is not visible.
depends on how badly split yours are.
regards
Gren
Old November 18th, 2008, 08:14 AM
turbodave
Dave C
1983 110
They are bad!!!
I've actually just realised that the early models had a definate 'gaiter' wheras what you buy now seems to be more like a square grommet so would be a lot more robust.
ac
95 column stalk cluster complete FS SafariHP The Vendors Loft 3 May 1st, 2008 08:28 AM
looking for advice on replacing the rear seat Doug Young Defender Technical Discussions 7 December 11th, 2004 05:40 PM
steering column u-joint Noah Defender Technical Discussions 0 September 8th, 2004 07:04 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
How to remove steering column? Chris Cox Defender Technical Discussions 6 October 22nd, 2003 07:24 PM
