Replacing sliding glass window - Defender Source
Old January 22nd, 2007, 08:43 PM
vesparover's Avatar
vesparover
brian bertolini
Hey All, So I broke the front sliding glass on the soft top window. I was curious as to If I should just have glass cut locally or search it out from a rover shop. The concern over just having one cut is the handle seems to be through the window- as in a non generic peice of glass with a handle glued on.
What have you guys done- I can't be the first to break a peice of glass.
Brian Bertolini
Old January 22nd, 2007, 08:55 PM
Its cheap to get the genuine part - maybe 40 dollars. The handle is also inexpensive. Its not hard to replace the glass, but you have to drill and replace the rivets holding the interior channel. Its also a good chance to replace the felt that keeps the glass from rattling. I think I have pix of the process.
ac, glass, window
Removing rear sliding window from pickup cab dave_lucas Defender Technical Discussions 2 October 31st, 2009 07:49 PM
Passenger side sliding rear window for a 90 or 110 roofside and one fixed window evilfij For Sale - Parts 2 June 2nd, 2009 10:46 AM
Help installing rear window glass PCRover Defender Technical Discussions 7 December 25th, 2007 02:44 AM
Replacing Door Top Glass on ST 90 mikeybob2@msn.com Defender Technical Discussions 3 October 8th, 2007 08:11 AM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
