replacing sensors in manifold - Defender Source
Old September 18th, 2004, 11:35 AM
mattdh's Avatar
mattdh
Matt Hurst
replacing the two sensors in the inlet nanifold, what if any thing should i put on the threads and does anyone know the torque settings.thanks for the help!
Old September 20th, 2004, 03:04 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
It's the intake (not high pressure), so it doesn't have to be super tight - just nice and snug. You don't need to put anything on the threads unless you'd like to put some anti-seize on it (eg if it's steel into aluminum you'll get more dissimilar metal corrosion). No teflon tape, etc, is required.
Old September 20th, 2004, 07:02 PM
mattdh's Avatar
mattdh
Matt Hurst
thanks for the input jason!! i was thinking if i need some kind of teflon tape or some thing to that effect?
Old September 20th, 2004, 07:33 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Nah, that's not required for a low pressure air seal. Consider that most of those hoses and things are just pushed into place. Teflon tape never hurts, but you don't need it.
Use teflon tape (or other thread sealer) for sensors on the cooling system or wherever there is not a pressure fitting but just a threaded-in piece (eg brake lines have a pressure fitting and don't need tape).
ac, sensor
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
O2 sensors disconnected. Marx-110 Defender Technical Discussions 3 July 26th, 2004 08:26 AM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
Complete intake manifold orlandog For Sale - Parts 0 February 29th, 2004 12:43 AM
intake manifold leaking JRowe Defender Technical Discussions 8 February 9th, 2004 05:02 PM
