Replacing Seat Foam? - Defender Source
Old August 31st, 2007, 12:33 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Can anyone point me to instructions on how to replace the front seat base foam? I have new foam, just wondering the best approach to replacing it.
Gary
Old August 31st, 2007, 12:42 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
I would check Exmoor's website. If you can't find anything consider the below, pretty easy and straight-forward:
Remove seat base, flip it over. Unhook metal rod in back, remove all the plastic push pins, then slide off the rubber retainer from around the rest of the seat. Pull off the cover. Rip off the existing seat base. Clean up the pan with a chisel, acetone, etc. Spray adhesive to the pan and foam. Install new foam. Re-install cover. Re-install rubber retainer around base of pan, ensure the cover is centered up. Re-install the metal rod in the back. And put the push pins back in.
Old August 31st, 2007, 10:31 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
just tear it apart and it quickly becomes pretty evident how to put it back together.
Old August 31st, 2007, 10:43 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Thanks for the info guys, I will be tearing into it this weekend.
Gary
Old May 13th, 2008, 07:40 PM
what about the seat backs id like to restuff mine, the material looks fine and isnt burnt to dirty etc.
Old May 13th, 2008, 10:43 PM
The seat back is easy too, its just more steps with the head rest and all. The hardest part is getting the lock-strip along the bottom of the upholstery to re-close.
New foam is so very pleasing.
Old May 14th, 2008, 10:30 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
This may help a little so you know what it looks like apart:
http://www.eastcoastrover.com/201.html
http://www.eastcoastrover.com/211.html
Email:
Old May 14th, 2008, 03:02 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I need to replace the seat foam in my DS seat base. Is Exmoor the best option for buying just the foam? Thanks.
Old May 14th, 2008, 05:48 PM
seems like the only option
Old May 14th, 2008, 05:52 PM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
Ryan,
I have 1 cushion foam in stock. Do you need any backrest foam?
Badger Coachworks
Sew on and sew forth...
Old May 14th, 2008, 06:03 PM
come on now....
Old May 14th, 2008, 07:32 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Chris,
All I need is the foam for the seat base. So I'm very interested in what you have. I'll contact you offline.
Ryan
Old May 14th, 2008, 10:56 PM
artm
Arthur Maravelis
97 SW
Have you not tried local furniture repair/upholstery shops? Cutting foam is what they do every day and they do it well. They can easily copy it from the other seat.
I recall an old guy here in Boston who used to do anything with foam. I only used him to take his scrap foam that I used for packing material.
Old May 14th, 2008, 11:45 PM
The foam is so inexpensive its hardly worth it to drive around and find someone to custom cut something. Plus the new molded part is superior to the old one and you know it will fit the first time. With some guy doing it, you have to wait until its done to see if you're satisfied.
ac
D90 Seat foam Capt Milks For Sale - Parts 0 February 13th, 2008 07:59 AM
Baby Car Seat QUESTION Flagg Misc. Chit-Chat 5 August 4th, 2007 06:39 PM
defender seat cushion foam for sale draaronr For Sale - Parts 14 May 17th, 2005 12:09 PM
looking for advice on replacing the rear seat Doug Young Defender Technical Discussions 7 December 11th, 2004 05:40 PM
OEM front seat covers and foam - used dmarchand For Sale - Parts 1 December 1st, 2004 09:30 AM
