replacing rear lights with LED, need some help on reverse - Defender Source
Old April 18th, 2014, 07:07 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I began removing the stock lucas lights on my 84 110 and installing plinths yesterday and I've run into a snag. When I removed the rectangular reverse light, I found that the wires were not connected to anything and quite corroded. I need to find the reverse light connections on the loom. Should I be looking for this on the same leg of the loom that feeds the left side of the truck? Most of the wires were over sprayed green but I should be able to clean some paint off to get to the original wire color. Appreciate any help you can offer.
Matt
Old April 18th, 2014, 07:27 AM
flananuts
Matthew
Quick update - thanks to better searching I found the diagram and the two wire colors that connect the lamp to the reverse switch and ground. Now I just need to find them and then test if they in fact still work.
ac, ht, lights
LED Rear Lights RoversNorth The Vendors Loft 3 February 18th, 2014 06:12 PM
JW Speaker rear LED lights Jbullis Wanted 7 October 24th, 2013 10:18 AM
WTB LED Rear Lights curry Wanted 6 December 31st, 2012 06:57 AM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 05:34 AM
Reverse led light part # needed FlaD90 Defender Technical Discussions 5 July 16th, 2010 08:35 PM
