Replacing pulley bearing - Defender Source
Old April 24th, 2004, 03:00 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I need to replace my bearings in the a/c tensioner pulley. Anyone ever done this? I don't have a press so I'm not sure I could even do it. The tensioner pulley needs to be replaced so If anyone has one the took out and don't need please let me know.Thanks
Old April 25th, 2004, 06:26 PM
bd90
94 Arles Blue #1644
How did you know it was the bearing? Was it making a squealing noise? Mine is doing that? I would try an A/C shop for help in removal and install of the bearing. Shouldn't cost too much. Did you have any problems removing compresso?.
Old April 25th, 2004, 11:12 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
tensioner bearing
You don't need to replace the tensioner. The bearing is $10 from NAPA and the whole job should take 30 min max. I attached a link so you can see pictures
http://photos.groups.yahoo.com/group...c=gr%26.view=t
If for some reason the link dosn't work, it's posted on Yahoo groups Tdi list under tensioner bearing in the picture section.
First take the belt off and remove the pulley. You don't need to remove the whole tensioner. You will see a small snap ring on the back side. It may have holes so you can use a snap ring pliers. It not, you need to pick it out. It's a bit of a pain but not bad. Once out, use a 1" scoket to drift the bearing out. Once out use the old bearing to drift the new one in. The bearing is NAPA # 6203-2RSJ and is the same for D90, V8 & Tdi as well as Disco 1. Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old April 26th, 2004, 08:37 AM
Campbell's Avatar
Campbell
Rich Campbell
THANKS A LOT GUYS!!
Old April 26th, 2004, 08:42 AM
Campbell's Avatar
Campbell
Rich Campbell
I can't view the pictures. Can you email them to me.
rcampbell13@yahoo.com
ac, pulley
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Need Crank Pulley RedRhinoProducts Wanted 0 November 16th, 2005 11:41 AM
Replacing 4.0 with 4.6 Trevor Tarr Defender Technical Discussions 17 December 15th, 2004 10:21 PM
AC Pulley, Tension Mike Hippert Wanted 4 July 29th, 2004 12:04 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
