Replacing NATO light switch - Defender Source
Old October 31st, 2015, 05:31 PM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
I successfully found the plug on the loom to install the civilian light switch.
The problem is that once I disconnect the NATO switch I lose the hazards and indicators.
I'm no electrician but I've tried using test light and multimeter to work out the issue but so far only found the permanent live.
I've dug deep on the forums and found plenty of people saying they managed this but no one saying how.
Anyone have any clues?
Old November 1st, 2015, 08:39 AM
mtsl500
MT
1986 90 (ex-MoD)
I have been researching this a bit, it's on the to-do list after
1.) Receiving the vehicle
2.) Registering the vehicle
3.) Driving the vehicle ... you get the point
I found the following circuit diagram, seems to be pretty straight forward to me hope it helps you (posted the link as the diagram is something like 1500x1100)
http://www.land-rover-lightweight.co...ircuitNewA.jpg
Also, if you're doing this and haven't installed a harness to add relays, might be a good opportunity ... everything I've read says you'll see a huge impact on the lighting as well as extend the life of any and all switches
Hope that's useful
Old November 1st, 2015, 09:27 AM
Hache
Henry Lambert
Thanks mate. Red90 on this forum has a very good circuit diagram for FFRs which has been useful.
Weirdly the wire colours in the diagram you posted don't correspond with my truck - do you know what year that diagram is for?
Either way I still can't workout why the NATO switch is necessary now that I've installed the civvy one.
Here's a bad photo of the wiring that goes into the NATO switch
Old November 1st, 2015, 09:29 AM
Hache
Henry Lambert
The image isn't clear but the wires are: brown, brown with white trace, red, blue, green with purple trace.
Old November 1st, 2015, 10:23 AM
The photo on the link above appears to be the circuit diagram for a series 3 lightweight, not a Defender.
Old November 1st, 2015, 10:25 AM
What I would do.... Disconnect the switch and mark which wires are live. Plug it in and now check which circuits are live. One or more of them must be joined with the switch connected in the off position. Once you figure out which ones are powered by the switch, you can install a jumper(s) on the plug after disconnecting it.
Old November 1st, 2015, 10:29 AM
mtsl500
MT
1986 90 (ex-MoD)
Appreciate the heads up, ordered the Military User Handbook and the Restoration manual to go with the workshop manual v8engine sent me, hope those help.
I'm trying to find the wiring diagram you have on here to bookmark that as well for this eventual undertaking
Old November 1st, 2015, 11:21 AM
Hache
Henry Lambert
Here's the diagram from Red90's site: http://www.red90.ca/rovers/Defender%...%20diagram.pdf
------ Follow up post added November 1st, 2015 09:25 AM ------
Thanks Red90. I thought I'd been doing that with the multimeter. I'll spend some more time with it because it should be relatively straightforward!
Old November 1st, 2015, 04:05 PM
Hache
Henry Lambert
Turns out just needed to bridge the brown to brown/white (permanent live to fuse box)
Old January 24th, 2016, 07:59 PM
LRDMOD's Avatar
LRDMOD
Kelsey
87 Defender 90 Ex-Mod
Hey I know this post was from a while ago but looking to do the same thing on my 87 MOD.
So replacing the NATO switch with a civilian switch is done by plugging in the new switch on the column and bridging the brown to brown/white (permanent live to fuse box)?
I have been trying to find more information on how to wire this but cant find to much as well.
Any other suggestions that people have found?
87 Ex Mod 90
91 RRC
Old January 24th, 2016, 11:12 PM
Hache
Henry Lambert
That's how I solved it. But others didn't need to bridge the multi plug behind the NATO switch.
Old January 25th, 2016, 08:01 PM
LRDMOD's Avatar
LRDMOD
Kelsey
I have been looking at Red90s diagram and this looks like the connector for the light switch correct?
87 Ex Mod 90
91 RRC
Old January 26th, 2016, 08:43 AM
LRDMOD's Avatar
LRDMOD
Kelsey
Never mind I realize now that that connector is for the Blackout lights.
I opened the steering column up but didnt find any open connectors that look like they would fit into the light switch.
Anyone have any other ideas where it can be or what to do if there isnt one?
87 Ex Mod 90
91 RRC
Old January 27th, 2016, 05:33 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Some looms had the "civilian" bypass plug built in, some didn't.
If you don't have it, then as said above, link the brown/brown-white, which will give permanent feed to the hazards (and via the ignition, the turn lights and brake lights)
From the NATO plug, there will be 3 wires that feed the lights (rear tail lights, front side lights, then the headlights).... off the top of my head, without looking at a diagram, I'm sure the tail and side lights are thin red wires (you can find out, by fitting the NATO switch and with a multimeter test to see which ones get power when you turn the switch to S and T)
anyway, the tail and side will need joining together, and these will connect to the sidelight feed from the new civvy switch,, and the remaining headlight wire will go to the headlight cable from the NATO switch
Old January 27th, 2016, 08:21 AM
LRDMOD's Avatar
LRDMOD
Kelsey
Thanks Diesel_jim, very helpful.
I was talking with Johns_D90 and he recommended I make a plate to house the NATO switch similar to where his is on his Australian 110. So I took the switch apart and moved it, hopefully it fits, so now I have the best of both worlds, black out switch and open dash!
But now that I know I could wire up the switch maybe I will go back to the orignal plan...
Heres a picture of what I made
87 Ex Mod 90
91 RRC
Old January 27th, 2016, 10:50 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
That's a really slick looking plate. Nice work.
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old January 27th, 2016, 12:33 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Nice. Great idea!
Old January 27th, 2016, 12:47 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Originally Posted by meatblanket View Post
Nice. Great idea!
I was just the consultant, thank the Aussies. For anyone curious it is Blackout lights, LT95 Diff Lock, dash light dimmer.
ac, ht, switch
Glow Plug Light turn on when dome light is switch is flipped on Elbee Defender Technical Discussions 4 September 9th, 2014 06:27 PM
light switch(like the dimmer switch) defender1844 Wanted 3 May 25th, 2014 06:42 PM
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Difficulty of Replacing Dip Switch? bradfordish Defender Technical Discussions 1 January 17th, 2014 12:36 PM
Aux. light switch (RRC headlight switch) $40 shipped evilfij For Sale - Parts 0 September 5th, 2008 05:12 PM
