Replacing my fuel tank - ROW / UK side mount - Defender Source
Old May 1st, 2012, 07:52 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So i could give you guys a long write up, but I found this one online and couldn't find anything on this forum - so i figured I'd get the link in here
http://forums.lr4x4.com/index.php?showtopic=19112
In short that write up is pretty much spot on.
The one thing I found is the bolts were stuck on my front support bracket, so I just cut the bracket in half, removed the gas tank, then removed the bracket and welded it back together, simple fix.
You need to remove the front bracket in order to drop the tank, and even then it requires some kicking and yanking.
Took about an hr to get the old one out, gonna put the new on in tomorrow and will follow up with any additional info.
FWIW - my tank started leaking exactly in the spot described in that link, a new on from RN was about $300 shipped.
EDIT:
I just got an idea - I'm thinking why not remove the battery/battery box from the other side, put in a second fuel tank and relocate the battery under the hood somewhere... I'm sure I could find a place to fit a battery in that engine bay, theres loads of room.
anyone do this before?
Old May 1st, 2012, 09:08 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I had a pair of alum tanks made a few years ago to replace the origional saddle tank & put a second under the battery side. I use a 2 way fuel & gauge valve to switch between them, works great & the motor doesn't even cough if you switch on the run
Here are a few pic's of them & the fuel filler I added to fill the second tank up.
ID:	50977   Click image for larger version
Old May 1st, 2012, 09:51 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I was thinking have the second tank just pump into the first....
where did you put your battery and how did you mount it
Old May 2nd, 2012, 09:03 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Made a box to go behind the tub bulkhead in the 90, now I'm rebuilding it again so have made a simple battery cradle for a pair of PC1500's. Same place as was in the tub... just not anymore
Old May 3rd, 2012, 08:28 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Looks like I'm getting lazy and am just gonna wrap up the single tank.... Thats why they made jerry cans right haha!
The battery box is on my list, when I cut the old one out maybe I'll get ambitous for this project.
Old May 3rd, 2012, 10:46 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Andy I really like those tanks you had made up. Do you still have the contact of who made those? or a drawing so I could get some made up? daniel. marcello @gmail.com
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 3rd, 2012, 04:41 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Sorry.... not got his # now..... but I do have a very nice CAD drawing I drew for him to make them from
I feel tokens are in order
Old May 3rd, 2012, 06:58 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I'm sure those tanks were a pretty penny, the proline replacement is about $300 shipped. Obvisouly there are advantages to an AL tank, but depending on the price point it might make more sense to go with a steel OEM replacement..
Way I figure it, if the steel one i just took out was good for 25 yrs, Im ok with this one lasting another 25
Old May 3rd, 2012, 07:08 PM
ini88's Avatar
ini88
Daniel Marcello
Sorry not to pull away from your topic Adrian, but I was hoping to fit two 12 gallon tanks under the driver and passenger seats I just know the tanks have a small dent in the front corner to clear that frame piece. I'm wounding if I could dent in the other side for the driver side too.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 3rd, 2012, 07:12 PM
bossman429's Avatar
bossman429
Adrian
1988 90
What dent are you talking about? Do you mean the angled corner? I dont think you'd be able to "dent" it in, its pretty stout material and about 2-3" of corner is "cut" off
Old May 3rd, 2012, 07:40 PM
ini88's Avatar
ini88
Daniel Marcello
yup that angled corner that misses the frame outrigger. Does your have it on both sides? meaning you could use it under both the passenger and driver?
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 3rd, 2012, 08:40 PM
Landy_Andy's Avatar
Landy_Andy
Andy
The OEM tank will only fit on the one side, that's why I had the alum ones made by my buddy in the UK.
There also a larger for a bit more range and have both the corners angled to miss both the front & rear suspension mounts. I looked at using a OEM tank on the opposite side and it'll be a royal PITA to reshape it without using a sledge hammer !
You'll also need to add the mounts onto the rear bulkhead out rigger & get a front tank mount, grind off the welds, flatten it & bend it back the opposite way. Weld up & presto you have the opposite hand mount.
Name:	TT 4_640x480.jpg
Old May 3rd, 2012, 09:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
All depends if your buddy own's a race car shop & builds stuff out of alum all the time.... doesn't it
Old May 3rd, 2012, 09:25 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Awesome looking work. A while ago some said that they had some tanks made up for about the same cost as OEM ones.
Old May 3rd, 2012, 09:29 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Haha that would help!
As you mentioned, the tank I got only has the angled corner on one side. The lip or flange thats halfway between both halves is about 3 or 4 pieces of steel sandwhiched together, so bending them isn't an option.
Andy if you have CAD drawings could you email them to me as well? I have a friend who can TIG weld pretty well, and a neighbor with a sheetmetal shop. I'm thinking between the two of them I coul get something made up
Old May 3rd, 2012, 09:47 PM
ini88's Avatar
ini88
Daniel Marcello
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 4th, 2012, 10:56 AM
Dave Bobeck did a fix years back and I had the same issue earlier this year.
Before you spend gas/tire money on a new tank, drill out the spot welds holding the skid to the fuel tank and remove it from the fuel tank.
If the rest of the fuel tank is in good condition then what you will most likely find are pinhole leaks in the bottom of the fuel tank where the skid meets the fuel tank. There is a cardboard mastic used by the factory to adhere the skid to the fuel tank. This absorbs water and rusts the tank from the outside in.
I had pinhole leaks. After cleaning and derusting the entire tank, I used 30 minute epoxy and fiberglass fabric and reinforced the bottom of the tank. I repainted the fuel tank and the skid, then riveted the skid back onto the fuel tank, then replaced the fuel tank into the truck.
It's been working like a charm ever since. It took about a week of my time, but only cost me $80 in chemicals/paint/parts to clean out and refurb the tank.
BTW - if you need to buy a new tank, British Pacific had them for $175 before shipping. If you're near them, I would give them a try first.
Old May 4th, 2012, 11:49 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Great help, but i already splurged on a new proline tank from RN
After the prying and smacking I had to do to get the old tank out, I dont think i would have been able to "repair" it lol.
Its all in and works great, just took it out for a bit, filled her up and no issues whatsover. I'm planning some longer trips in the next year or two and the peice of mind of a brand new tank is worth the extra couple hundred for me..... not to mention it only took about 2 hrs total from start to finish.
Old May 4th, 2012, 01:25 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Wow Andy those tanks look great. If its not too big of a deal would you also be willing to share CAD drawings with me? I need to do something with mine since it was half full of water and fuel and rather small. Thanks. jeffro3 at mac.com
ac, fuel, fuel tank, mount
Factory Aux. Fuel Tank? Willh Misc. Chit-Chat 20 May 10th, 2010 09:39 PM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Rimmer Supercharger, complete. Also side fuel tank. Tom Fitzgerald For Sale - Parts 14 December 12th, 2005 08:09 PM
Dropping the gas tank Gkase Defender Technical Discussions 33 December 1st, 2003 08:59 AM
