Replacing License Plate Light - Defender Source
Old January 20th, 2015, 04:36 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Replacing the light assembly for the license plate and am wondering how to connect the original wires to the new light. It has barrels for crimping the wire in place, not sure how I can get crimping pliers in such a tight place. Any suggestions? Thanks.
ID:	111648   Click image for larger version
Old January 20th, 2015, 04:37 PM
The ends of the wire have bullets that go into those holes.
Old January 20th, 2015, 04:45 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
yes just a "plug in" bullet that is already crimped on the wire. Think of it as a British quick disconnect!
Old January 20th, 2015, 04:46 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
hmm, looks like the original wires do not have the bullets
ID:	111651   Click image for larger version
Old January 20th, 2015, 04:49 PM
Bill Larson
Bill Larson
someone must have cut it off and rigged the smash crimp. you can buy the bullet plugs just Google it...
Old January 20th, 2015, 08:29 PM
Someone should be shot for that fix. Yes, bullets are available. I bought a huge bag for like $20 years ago. Ideally you want the special tool, but a normal crimper does work ok.
Old January 20th, 2015, 09:14 PM
MGPete's Avatar
MGPete
Pete C
'95 D90 SW
That application actually uses a removable type bullet connector. It looks like a barrel with hole in the end and a slit along the side.
You feed the wire through and out the front of the bullet and lock the wire into the slit to hold it in place as you press it into the holder in the light.
Yes, you can use a true bullet connector, but as has been pointed out, you'll need the special crimp tool OR you buy the solder on bullet connector.
www.britishwiring.com
I have and can send you the little removable connector bullet if you'd like. Since your in Dallas, look up Kip Motors and he can hook you up with what you need.
Pete
Old January 20th, 2015, 10:12 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
I got one of that style from George Down South. Didn't care for the bullet connectors so what I did was with a pair of wire cutters is split and un-roll and shaped to fit a female spade. Worked great and worked for years.
Old January 20th, 2015, 11:28 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I just ordered this LR license plate light kit from Rovers North and may have the same issue. Please let me know what you ordered for bullets or how you connected it. Would be very appreciated. Thanks.
ac, ht, license plate
Bulkhead VIN plate and 4WD plate and tow plate o2batsea Series Technical Discussions 3 July 16th, 2013 03:12 PM
License Plate Light replacement josh-man Defender Technical Discussions 15 July 10th, 2013 01:11 PM
Series License Plate Light kzack For Sale - Parts 2 August 6th, 2012 10:57 AM
License plate light for 97 defender cafemosaic Wanted 7 February 3rd, 2012 09:31 AM
Rear License Plate Light Wiring Alex D90 Smaller Projects 2 November 2nd, 2008 11:27 PM
