Replacing headlight bulb? - Defender Source
Old May 10th, 2015, 12:49 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
I have a stupid question about changing the headlight bulb. Do you have to remove the light bezel and pull it out from the front, or can it just be unplugged and pulled from the rear? I have Hella H4s.
Old May 10th, 2015, 12:50 PM
You need to pull it out. There is no access from the back.
Old May 10th, 2015, 01:25 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks, kind of what I figured. Even the simplest jobs on these things are labor intensive.
Old May 10th, 2015, 02:46 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Do you have one piece sealed lenses with bulb or H4 bulbs in the lens/holder?
If they are one piece sealed units you will need to pull everything from the front.
If they are bulb and holder, no tools are needed. Pull the clips from the rear, swap the bulb, curse while you contort yourself to get the damn clip back on, and done...
Old May 10th, 2015, 07:02 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
If you're upgrading bulbs, make sure you put relays in (like arb m002)
Old May 10th, 2015, 11:57 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
I have the H4, so it's just the swap of a bulb. I just have a low beam on the drivers side out.The relay upgrade will be done in the near future.
ac, ht
H4 retrofit lens/bulb combo = dim lights! jaherring Defender Technical Discussions 1 January 18th, 2005 12:37 PM
Side Marker Bulb Replacement Matt Klapmust Defender Technical Discussions 8 December 23rd, 2004 06:09 PM
Instrument light bulb / Sylvania replacement Mark M Defender Technical Discussions 2 November 17th, 2004 04:23 PM
Clock Light Bulb ronward Defender Technical Discussions 1 April 28th, 2004 04:13 AM
Side lamp bulb holder Neo Defender Technical Discussions 5 January 30th, 2004 05:07 PM
