Replacing front light surrounds - Defender Source
Old February 20th, 2016, 01:38 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Hello,
I am replacing the plastic light surrounds on my 1988 110. I am having trouble disconnecting the front indicator and side light. Any suggestions about how to do this?
Ben
Old February 20th, 2016, 01:47 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Cut the wires and replace with some sort of connectors. Pretty simple.
Old February 20th, 2016, 02:13 PM
There should be bullet connectors. They are a fairly long lead. Maybe two feet.
Old February 20th, 2016, 02:17 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Would I access that from inside the wing?
Old February 20th, 2016, 02:19 PM
generalcutter's Avatar
generalcutter
Daniel
1988 Defender 110
what are you using for a replacement? Does anyone make a metal version?
Old February 20th, 2016, 02:49 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
I am just using a black plastic surround from rover north. I just want to replace the older body colored units.
Old February 20th, 2016, 03:51 PM
Yes. Just follow the wires.
Old February 20th, 2016, 04:01 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Thank you
Old February 20th, 2016, 04:09 PM
The original surround could be removed with the lights in place. Unfortunately, nobody sells that style anymore.
Old February 20th, 2016, 04:28 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
If you take out the headlight buckets you can reach the wires, but I cut mine when I replaced with LED's..
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 20th, 2016, 04:32 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
I plan to go back with LED at some point. Can I ask where you got yours from?
Old February 20th, 2016, 05:25 PM
Ben - did you have to remove the arch eyebrow to get behind the wing?
Old February 20th, 2016, 08:13 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
I have not finished yet but can see the wiring from within the wing - I just need smaller hands!
Heritage light surrounds- Nakatanenga timtimtj For Sale - Parts 2 February 24th, 2015 08:47 AM
Defender vs series 3 front wing panels and light surrounds Wilboro Defender Technical Discussions 7 March 13th, 2014 05:47 AM
Putting front light surrounds on an exmod 90 meow Defender Technical Discussions 9 September 14th, 2013 10:47 PM
NAS front grill and light surrounds Fivespddisco For Sale - Parts 27 June 11th, 2011 12:43 PM
td5 grey grill and light surrounds bjf Wanted 2 July 17th, 2010 12:18 AM
