replacing door cards - Defender Source
Old July 26th, 2010, 08:27 PM
grbec22's Avatar
grbec22
Roger Ramjet
1985 "90" no defender's back then.
What is the best way to go about changing the door cards on an early defenders (85)?
Old July 30th, 2010, 09:16 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Put nylon inserts into the mounting holes and then use stainless screws to attach them using those clip-on caps to cover the screw heads. This is how I re-attached all the panels secured with plastic fasteners in the D2 and it completely eliminated all of the squeaks and rattles (from those panels).
While you're there I'd also put a layer of (inserting cheapest comparable material) RAAMmat BTX on the inside surface, it will reduce vibration/noise but it will also provide a waterproof seal. I'd also put a liquid seam-sealer into the gap between the skin and frame at the same time to keep it as dry as possible. The same people who sell RAAMmat also have an adhesive closed cell (likely neoprene) foam they call Ensolite that could be used over the damper to provide some additional sound-absorbing capacity.
ac, door
Replacing sagging Headliners in Defenders - material and success? COSteve Defender Technical Discussions 8 April 27th, 2005 05:41 PM
Replacing 4.0 with 4.6 Trevor Tarr Defender Technical Discussions 17 December 15th, 2004 10:21 PM
looking for advice on replacing the rear seat Doug Young Defender Technical Discussions 7 December 11th, 2004 05:40 PM
replacing sensors in manifold mattdh Defender Technical Discussions 3 September 20th, 2004 07:33 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
