Replacing complete axles on a 110 - Defender Source
Old January 27th, 2011, 09:13 AM
willr's Avatar
willr
WILL RAGSDALE
NONE
I just bought 2 complete axle assemblies for my 110 and I am curious about the amount of time it will take to install them. They just bolt right in so I am not sure how difficult the job is. Can someone coach me up on the time it will take to complete the project.
Old January 27th, 2011, 09:24 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
It all depends on how mechanically savvy your are. If you've never done it before, I'd give yourself a weekend, or a day per axle. It's not hard, but rusty bolts and things not lining up will give you fits.
If you are lucky enough to have help, then maybe a full day.
Good luck and let us know the actual time!
Semper Fi!
Old January 27th, 2011, 09:59 AM
have lots of cutting wheels or a hot wrench handy in the event the bolts are rusted to the bushings.
Old January 27th, 2011, 11:01 AM
grnrvrs's Avatar
grnrvrs
Paul
88
in addition to cut off wheels , an air wrench will be your friend.
Old January 27th, 2011, 02:08 PM
sawzall or blue wrench to burn out the radius arm or trailing arm bolts @ the axle end. Just in case. Ask me how I know...
depending on what is what with the brakes, you may want to keep your current calipers attached to their lines and dangling off a bungee or tie wrap under the truck. That will save you time bleeding brakes. But will cost time removing the calipers.
Old January 29th, 2011, 03:46 AM
willr's Avatar
willr
WILL RAGSDALE
NONE
Thanks for the advice.
110, ac, axle
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
110 Hi-Cap Complete CDK for US Build SafariHP For Sale - Parts 0 July 12th, 2006 07:04 AM
110 Military Swivels, balls, CV's, complete outer Buckon37s For Sale - Parts 20 November 3rd, 2004 12:14 PM
