Replacing Cantrails, need advice! - Defender Source
Old October 7th, 2006, 07:50 PM
Harrisonml
Mark Harrison
94 / D-90
Just bought two new cantrails. During the replacement I ran into a couple of isses I need help with. The first is simple. In removing the rear cross over bar, one of the star head bolts stripped. I need to find a place where I can replace all the bolts. Anyone know where I can find these or what they are called?
The second is a bit more challenging. The light weight bar that crosses over from one cantrail to the other and supports the soft top will not come out of the cantrail. It looks to be pressed in and seems like it should just pop out but it won't. In trying to pull it out, the pin in the bar is bending out and it does not seem like an easy part to replace. Does anyone have any idea as to how to remove this bar from both cantrail without damaging it?
thanks!
Mark
ac
Advice on replacing TDI300 Turbo Eddie 1 Defender Technical Discussions 7 February 1st, 2008 01:22 PM
Requesting a little suspension advice nmc Defender Technical Discussions 9 March 19th, 2006 01:09 PM
Advice need!!! Please help!!! reaper99999 Defender Technical Discussions 10 February 9th, 2006 08:49 AM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
looking for advice on replacing the rear seat Doug Young Defender Technical Discussions 7 December 11th, 2004 05:40 PM
