Replacing brake fluid - Defender Source
Old September 24th, 2006, 11:17 AM
Antonios
Antonios Hadjigeorgalis
No more
I just replaced my brake fluid and installed braided stainless hoses. I bled the brakes using the motive powerbleeder and it all seemed pretty easy. But now I notice that the fluid in the front of the main reservior is clear while the rear of the reservoir is darker. I assume this means I didn't bleed out all the old fluid from the rear circuit.
I still have some clean fluid in the powerbleeder so if I reattach it and bleed more fluid out of the rear would this replace only fluid from the rear circuit?
This seems logical and may be a stupid question but this is my first time replacing brake fluid.
Thanks in advance for any input.
Miami, FL
Old September 27th, 2006, 08:27 PM
mffoster
Mike Foster
94 D90, 2007 Supercharged RR
The trick is to remove the old fluid from the reservior and replace it with new before beginning to flush the lines. The easiest way is to buy a cheap plastic turkey baster. Use it to pull all the old brake fluid out first. Refill the reservior with new fluid, then bleed. This way you don't have to push all the old stuff through the system. Wash out the baster when you're done and keep it in the Motive Powerbleeder box (those things work great, by the way). I always use Castrol GT Lma brake fluid.
Mike F
94 D90 since new
Old September 27th, 2006, 09:09 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yup, baste the turkey, keep flushing until clear. Make sure brakes are bled in proper sequence.
ac, brake
Brake Fluid Resv. Switch mpsteil Defender Technical Discussions 6 October 29th, 2009 09:51 PM
Brake fluid leaking into servo? easy Defender Technical Discussions 3 August 3rd, 2009 04:55 PM
Brake fluid Defender13 Defender Technical Discussions 2 August 27th, 2007 09:33 PM
