replacing belts...how to release tension - Defender Source
Old July 18th, 2011, 03:14 PM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
'95 D-90 with AC
not the kind I'm feeling after replacing the master/slave/flex hose kind...WAB; but the belt tensioners. Trying to replace all 3 belts; alternator serp straight forward...'95 classic has a nut to wrench...not the D-90
Old July 18th, 2011, 06:19 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Both are loosened from the bottom / underneath using a 13mm socket on a long extension. The ac tension can also be reached with a wrench from the top.
Here's a pic of the ac tensioner. Water pump tensioner looks the same only lower down by the crankshaft pulley.
ID:	40455   Click image for larger version
Old July 18th, 2011, 07:36 PM
PMKColorado
Paul Koentges
thanks...I thought they might be a spring tensioner similar to an '95 classic...on to the belt removal
Old July 18th, 2011, 07:58 PM
A knife
ac
Replacing Belts and bonus question california Defender Technical Discussions 11 March 26th, 2011 12:48 AM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Fan Belts Replacement kleedee Defender Technical Discussions 6 August 15th, 2005 09:15 PM
BFG MT 265/75, winch bumper and rear seat belts jvelador Wanted 0 September 26th, 2004 02:50 AM
rear seat belts flap in wind ONDROX Defender Technical Discussions 14 August 19th, 2004 11:56 PM
