Replacing a 1997 NAS ST frame - Defender Source
Old June 8th, 2011, 05:58 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Was wondering which option is better for replacing an NAS frame if you were going to swap to a 300TDI?
1) 300Tdi galvanized frame for a 90
2) 300tdi galvanized frame for an NAS truck
Other than fitting the NAS fuel tank, are there any differences?
Old June 8th, 2011, 07:26 AM
draaronr's Avatar
draaronr
Here
LR3
motor mounts, cross members, radiator mounts, all easily changeable before
Old June 8th, 2011, 09:33 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Are you talking about buying a new galvanized frame?
If so I would buy one that is setup as a NAS frame (for the tank and cage) but with the proper 300tdi mounts / bits if possible. The rear tank from a NAS is huge and in a better location than the standard 300tdi tank.
Old June 8th, 2011, 09:37 AM
TS888's Avatar
TS888
Tony Sims
1984 110
X2. If you're buying new, you should be able to order with the config you need. I think the NAS-style rear tank on a 90 is preferable to the ROW saddle tank as a primary fuel tank -- bigger and easier to protect.
If you're building, then a NAS frame with 300TDi mounts. The mounts are dead simple.
Tony
1984 110 "Smokey" (sold)
Old June 8th, 2011, 09:56 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Yes, it would be a new galvanized frame.
How does an NAS frame suit the cage better?
Old June 8th, 2011, 10:21 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Are the cage mounts integral (i.e. welded) to the NAS frame, or bolt on? If former, then that's the answer. I dunno, I have limited NAS exposure, I just know they got rear tanks instead of saddles, and that is good.
Tony
Old June 8th, 2011, 12:55 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
The NAS frame has 3 holes on each side that you install nutserts in and attach the under tub bar.
All NAS frames I have seen have them where none of the ROW frames I have seen have them. It would not be a big deal to drill the holes but then you would expose the bare steel.
1997, 97, ac, nas
1995 D90 NAS Frame, 3.9L V8 & Radiator for sale Barnett Childress For Sale - Parts 10 June 22nd, 2005 07:38 PM
uk windshield frame vs. nas d90? steved90 Defender Technical Discussions 3 April 5th, 2005 09:07 AM
For Sale 1997 NAS D90 Special Edition #019/300 GMAX For Sale - Vehicles 3 November 23rd, 2004 09:20 PM
Stock 1997 NAS Exhaust ronward Defender Technical Discussions 2 October 5th, 2004 08:18 PM
WTS: 1997 NAS D90 Workshop Manual artm For Sale - Parts 1 October 14th, 2003 12:20 AM
