Replacement Suggestions for facet fuel pump/filter - Defender Source
Old December 24th, 2014, 06:51 PM
toad's Avatar
toad
Cutter
I have been battling a leaking fuel filter on my 86 110 with the fuel pump and filter mounted to the RH frame. I bought a new filter assembly from rovahfarm but the threads are different on the inlet/outlet. I feel like rather than fighting with this thing if rather find a low cost fuel pump and filter to swap in. Anyone done this or have any recommendations.
Old December 24th, 2014, 07:04 PM
Diesel? Gas? Carbs? EFI?
Old December 24th, 2014, 07:13 PM
If you have a 2.5NA diesel I have a take off fuel filter assembly and a brand new filter that I will sell cheap. PM me if you are interested.
http://www.defendersource.com/forum/...ghlight=filter
Dave
Old December 24th, 2014, 07:27 PM
toad's Avatar
toad
Cutter
Sorry guys, my sig lists it but I should have said it's a 3.5 v8 original dual stromberg carbs
Old December 24th, 2014, 10:31 PM
Facet is the leading aftermarket fuel pump manufacturer as well. Any 12v fuel pump for a carburated application will suffice. That said the original facets seldom die, they usually just need the ground cleaned up if they quit
Old December 24th, 2014, 10:35 PM
phoenix37's Avatar
phoenix37
john
Ive got an extra facet pump I've never used that you can have. Ill be visiting my Dad in RI this weekend. Send me a PM if you want me to bring it down.
Old December 25th, 2014, 03:25 PM
toad's Avatar
toad
Cutter
Thanks John, my pump is fine so hang onto yours. Turns out the leak last night was from my tank sender, frustration somewhat blinded me. I'll probably get some properly sized compression fittings for the filter housing and stick w what I have.
ac, fuel
2.5 NA Fuel Filter replacement question josh-man Defender Technical Discussions 19 July 29th, 2016 06:54 PM
2.5 NA/2.5TD Fuel Filter head with NIB Filter. hillstrubl For Sale - Parts 3 June 1st, 2013 11:46 AM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
Left front skin, TD5 fuel filter, Fuel Pedal, mystery parts tomaco1 For Sale - Parts 12 August 24th, 2011 01:13 AM
