Replacement Rad choices - Defender Source
Old February 12th, 2009, 11:42 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Should I pay $400 to have the Rad recored on my 200 or Try and find a new one? If thats even possible.
Old February 12th, 2009, 11:46 AM
You should do whatever Pendy recommends.
Old February 12th, 2009, 11:56 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
stop messing with me! i told you id have a million questions.
Old February 12th, 2009, 12:00 PM
I think a new one with IC is going to be 600+, so if you IC is good, you might be money ahead to have the current one recored. I've had good luck with recores from good shops.
Old February 12th, 2009, 12:08 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks Exactly what Pendy Said!
Where can you get one for$600
Old February 12th, 2009, 12:11 PM
Thats what I paid for my new 300 rad/IC combo way back when, I just assumed the'd be similarly priced and higher by now. It came from RDS.
I'm running a RN aftermarket one and have been happy with it. Truck runs right @ 180 degree's. Less than $300
Old February 12th, 2009, 01:05 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You will be money ahead to get the Allisport stage 1 intercooler. Best to recore the radiator you have. If you do not have a radiator I can have one built from a core. I may have a leftover stock intercooler as well. This is a good time to spend money on the project though. Instead of going cheap and having problems in the near future.
Do what Cheney says!
We will see haw the summer goes. But I hope for the best! What core and core design is the RN?
legend in my own mind
Old February 12th, 2009, 02:26 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Is there something special about the 200TDI radiator? Seems expensive
Old February 12th, 2009, 03:11 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
send me the dimensions of it. I had my Disco done with a HD core for about $265 and that included adding a drain cock. If you want I can get a quote here. Even with shipping I'm sure it would be less than $400.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 12th, 2009, 04:08 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
I bought one from pendy with the oil cooling line delete, I've never seen the needle go past midway through the gauge since it handles the three thousand feet in 8 miles at 55 mph no problem
ac
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Rear Door Hinge Replacement Rob Defender Technical Discussions 2 January 21st, 2004 01:26 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
