Replacement of Land Rover D90 rear left panel. - Defender Source
Old July 14th, 2009, 12:10 PM
seriesgarage's Avatar
seriesgarage
John Bradley
1995 LR D90
Need a better idea on the replacement of a rear left panel for a D90. I've noticed two styles available on the market and was wondering the difference between the two . Any help would be greatly appreciated.
ID:	20560   Click image for larger version
Old July 14th, 2009, 12:20 PM
One has the cut out for the light. The other one is the ROW style from the really early trucks without side lights. I would go for the cheaper one and cut my own holes unless you know the black one has the right holes for a 1995/97 (94 had different lights as did the euro ROW trucks with side lights).
Ron
Old July 14th, 2009, 01:48 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
John:
Ron is correct- I looked into this when I had to replace the same panel on my truck.
Once challenge you will have (if you are a perfectionist) is that there in no real way to spot weld the replacement panel in the same locations as the factory so it will be apparent the panel was replaced. You could, as I did, replace the entire left rear body section (including wheel well) so this is not a problem. Or you can have a talented body guy 'fake' the spot welds which can be done but will take some time.
All the best with your project,
CARL
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old July 14th, 2009, 10:54 PM
black diesel
Kyle Caskey
Originally Posted by Green Blood
John:
CARL
That's what I did and would do for sure. I don't recall any welding needed to do it this way unless maybe on the steel section at the lower along the crossmember.
Old July 14th, 2009, 10:57 PM
You have to aluminium weld the support beam that goes around the back I think, but that is no biggy relative to all the spot welds. Keep in mind that a whole tub side is expensive. I would be temped to go begging for a whole used tub from the usual suspects.
90, ac, d90
left rear panel for 109" tub cgalpin Wanted 0 August 27th, 2009 09:45 PM
D90 Rear Left Eyebrow Old Stock or Set of New Stock seriesgarage Wanted 2 July 15th, 2009 12:03 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Need Rear Bench Seat For '94 D90 dreone73 Wanted 1 June 3rd, 2004 12:36 PM
