Replacement of Chequered Plates - Defender Source
Old July 25th, 2013, 02:47 PM
m1cr0ch1p
Daniel
2007 / Defender 90 2.4 TDCi
I have a set of chequered plates fixed to the top of the wings on either side of the bonnet, and the bolts are rusty so I would like to replace them.
How do you replace these bolts? Do you need to dismantle parts of the body to be able to get in and hold the nuts in place while tightening? Or should this be possible by opening the bonett and squeezing your hand through?
The land rover is a Defender 90 County model, with a 2.4 TDCi engine.
Old July 25th, 2013, 02:51 PM
not sure many people here would be familiar with vehicles so new ...
Have you tried undoing them ... what happens?
Old July 25th, 2013, 02:54 PM
Have you even tried to stick your hand in to see?
They could have installed them using rivnuts.
Old July 25th, 2013, 03:26 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Post up a couple photos of the chequerplate. Probably done with locknuts and you should be able to reach in to hold the nut with the bonnet open.
Defender Parts, Service, Restoration, and Training
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
rancho bushing replacement? jorge Defender Technical Discussions 6 April 7th, 2005 03:36 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
