Replacement of a brake light switch - Defender Source
Old December 10th, 2016, 10:52 AM
Chuck Chambers
1989 turbo diesel 90
I had a hesitancy to replace the brake light switch on my 1989 td Defender.
After correcting some wiring issues, cleaning all the grounding points in the system, I was able to get the brake lights operating by using a jumper wire across the terminals. So, isolating the final problem to the switch, I replaced it.
The old switch came out without having to remove the brake master cylinder and booster unit. I did not have to loosen and remove the brake pedal tower. By working at the top of the tower, right up against the firewall, and its cutout/relief, the new switch went in. A slight adjustment for the 5mm pedal stroke to illuminate the brake lights - and I was done.
Total time for this switch replacement was 25 minutes. As I do not have a garage and it was 28F here in Santa Fe, I am pleased that it did not take longer.
Old December 10th, 2016, 12:35 PM
taoseno's Avatar
Todd Kendrick
1995 D90 #2206 Original Owner
Funny just did mine a few months ago as well. We have lot of Rover guys that hang out in the SW; if you are up this way look me up..............
'95 D90 #2206
'66 109" P/U
ac, brake, ht, switch
Best brake light switch? o2batsea Defender Technical Discussions 1 March 30th, 2014 07:28 PM
Brake light switch bjf Defender Technical Discussions 1 November 24th, 2011 11:07 AM
Brake light switch replacement / diagram? Hans Defender Technical Discussions 0 April 16th, 2011 09:00 AM
Parking Brake Switch/Light Rocketman Defender Technical Discussions 2 December 20th, 2010 08:42 AM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 06:02 AM
