I'm looking for a replacement a/c compressor for a 1994 Diavia AC system. The compressor I currently have (not sure if it's original) is a Sanden 7851. I'm having trouble locating this unit. What do you guys recommend for a replacement? anyone have a part number available?
I did a search here, and someone mentioned using a Sanden 7819, but the rotor is 125mm. I measured mine and it looks to be 132mm. Also the 7819 has a single wire bullet connector, whereas mine has a female Packard connector. I supposed I could change the connector.
any ideas?
any ideas?
