Replaced fuel pump, truck won't start - Defender Source
Old July 23rd, 2010, 01:39 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Damn, another won't start thread...
Truck was running fine two weeks ago when I dropped the tank to install a Dixon-Bate tow jaw. Decided to replace the fuel pump while I was at it (bad idea).
Replaced the fuel pump and had all sorts of hell with seized fittings and rusted fuel skid bolts. Finally got everything back together and now the truck won't start. When I turn the key, I hear the fuel pump run for 2-3 seconds and then it stops. Then I crank the starter but the truck doesn't turn over. After the starter stops cranking, I hear the fuel pump run for another second or two.
Tank has one jerry can's worth of fuel in it.
I'm depressed and out of ideas.
Priming issue? How would I check fuel pressure on my 94 truck?
Old July 23rd, 2010, 12:29 PM
chris snell
Chris Snell
87 Ex-MOD 110
Problem solved: fuel supply and return hoses were swapped at the fuel pump connectors. What a dumb-ass. Too many long nights of work on this stupid project, I guess.
ac, fuel, start
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Fuel Pump, Switch, Relay, or Wiring? bbandit Defender Technical Discussions 19 July 10th, 2005 12:08 PM
external fuel pump snuffer Defender Technical Discussions 8 May 9th, 2005 04:14 PM
