replace water pump on 95 RRC - Chattanooga - Defender Source
Old December 22nd, 2015, 09:23 AM
signalMTB's Avatar
signalMTB
Rusty
'97 NAS D90 / '94 RRC / '05 L322
I need to replace the water pump on my RRC, 2 questions for you all...anyone have any opinions on all the aftermarket ones out there (Proline, AllMakes, AllMakes OE, Beck Arnelyetc.)?
I see lucky8 has the AllMakes OE for $90, probably just go with that unless there are big objections.
Second question...anyone in the Chattanooga area have a fan removal tool I can borrow?
Third question...anyone on this forum even remotely live near Chattanooga?
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
many others that have sold
Instagram: @SecondDailyClassics
Old December 22nd, 2015, 09:47 AM
ezzzzzzz
Mark Garrenton
They're all comparable in quality. I typically buy locally from Bap-Geon but use Trevor at Rovahfarm frequently. You can rent the tool for free at most auto part stores (you pay for it then get refunded when you return the tool). Do not remove the serpentine belt prior to loosening that fan clutch as you'll need all the leverage resistance you can get. Shock the fan clutch nut using a heavy rubber mallet or similar to smack the 36mm wrench. Just pulling on it isn't going to work. I don't use the pulley wrench that levers against the pulley bolts because these 10mm bolts can easily be damaged or shear off. If the water pump pulley rotates you'll probably need to remove the belt and use a strap wrench to hold the pulley firmly. An extra set of hands comes in handy here. It loosens counterclockwise. Be sure to lube the water pump threads with a copper based anti-seize before reinstalling the fan clutch. After you've got the fan clutch installed give it a light tap on the wrench to snug it (clockwise).
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old December 22nd, 2015, 10:06 AM
signalMTB's Avatar
signalMTB
Rusty
[QUOTE=ezzzzzzz;700216]They're all comparable in quality. I typically buy locally from Bap-Geon but use Trevor at Rovahfarm frequently. You can rent the tool for free at most auto part stores (you pay for it then get refunded when you return the tool). Do not remove the serpentine belt prior to loosening that fan clutch as you'll need all the leverage resistance you can get. Shock the fan clutch nut using a heavy rubber mallet or similar to smack the 36mm wrench. Just pulling on it isn't going to work. I don't use the pulley wrench that levers against the pulley bolts because these 10mm bolts can easily be damaged or shear off. If the water pump ...[QUOTE]
hey, thanks for the advice...good idea on renting the tool also. Won't be able to touch it for a week or so, the 951 failed emissions and the L322 is in need of a new compressor. drowning in car repairs at the moment.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
95, ac, water, water pump
RURR - Chattanooga to New Orleans to Chattanooga in October champana Misc. Chit-Chat 0 August 16th, 2015 05:48 PM
RURR - Chattanooga to Little Rock to Chattanooga champana Misc. Chit-Chat 3 August 12th, 2015 09:37 AM
Injector Replace / Rebuild / Nozzle Replace icnsltmfg Defender Technical Discussions 8 April 29th, 2015 08:29 PM
1993 Land Rover Defender 110 NAS 300tdi Diesel - $49999 (Chattanooga,TN) nathanwind The Flea Market 3 October 26th, 2011 03:38 AM
Anyone in Chattanooga TN?? JBOD77 Misc. Chit-Chat 6 October 5th, 2009 12:38 PM
