Replace hub seal surface on axle spindle? - Defender Source
Old April 29th, 2012, 10:38 AM
I know I can get a used axle spindle from a disco, but was wondering if the hub seal surface is replaceable like they are on the series? I have searched but can't find any equivalent to this for the defender
http://www.roverparts.com/Parts/1223.cfm
It *looks* like it could be replaceable on my spindle but want to buy a replacement before taking a chisel to it.
Originally Posted by pendy
I'm here for the D's
Old April 29th, 2012, 10:50 AM
I'm already stuck waiting for parts so I think I'm just going to hit Randy up for another set of spindles. If I had a lathe I'd give JB weld a try!
Seems silly they dropped the "feature".
Old April 29th, 2012, 11:39 PM
Charles, before you JB check out Speedi-sleeves. I had scoring on my rear pinion yoke, used one and it sorted it right out. Best $20 fix ever, Napa generally has them or can get them (or Amazon).
http://vsm.skf.com/en-US/HeavyDuty/K...ediSleeve.aspx
Old April 30th, 2012, 08:12 AM
I have heard of them but never tried them before. I was under the impression you'd need to change seal sizes but it doesn't appear so. In any event, I'm just going to get some better condition used ones from a D1 from Randy. My truck is half disco anyway and I think this is a better solution too.
Old May 1st, 2012, 06:08 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah, the distance piece on defender, disco, etc stub axles aren't replaceable. Frustrating. I guess it was a cost savings thing.
x2 on the speedi-sleeve. I've used them with great success on other things.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 1st, 2012, 08:41 AM
I'll look into the speedi sleeve to refurb my old ones and keep them as spares!
Old May 1st, 2012, 08:46 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
When you do let me know as I wouldn't mind doing the same thing!
Old May 1st, 2012, 08:51 AM
Hey you need a new avatar. There is a new lavatar available - grab it while it's hot!
Old May 1st, 2012, 09:20 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
where? haven't been on the threads enough yet
Old May 1st, 2012, 09:32 AM
http://www.defendersource.com/forum/...0&d=1335832879
Old May 1st, 2012, 09:39 AM
Just add flames in Photoshop...
Old May 1st, 2012, 09:40 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Attachment 50857
Charles, I have a new stub axle you can have half price + shipping, might even have two
3rd low and BOOT IT
Old May 1st, 2012, 09:46 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
well since you insist! actually I don't have time to play with it yet so I will keep the picture untouched just to claim it!
Old May 1st, 2012, 09:55 AM
Jimmy! Good to hear from you.
I already have a used pair on the way, and need them by tomorrow to have any chance of getting my truck back together by Friday.
But if they are not as nice as I'd like, I'll get back to you, thanks!
Old May 1st, 2012, 09:56 AM
Good call. Zoom in some when you do chop.
Old May 1st, 2012, 10:36 AM
carlosz's Avatar
carlosz
Carlos
Charles the spindles vary in lenght between abs and non abs, the abs is shorter thus the replacement you are getting may not work... I found out this crap about 7 yrs ago whenconverting frankie to a 24 spline abs (the only way 24 comes) from a 10 spline non abs... the 90 and up abs spindles with 10 spline drive train are the same as 24 spline.
when doing the swap, you will need the abs hubs to go with the abs spindles... Iknow it gets confusing but once you compare then (if at all possible side by side) you will see the difference between apples and oranges.. for that matter the seals are different as well.. I even tried mixing and matching parts to know avail... it is all or nothing.
I know you are not doing a swap, im just dragging the illustration to point out the difference in spindles.
Old May 1st, 2012, 10:52 AM
Thanks Carlos. Lucky for me Randy is well aware of the differences and went through this with Huff recently as well. I measured and he's sending me some non-abs ones (i'm not sure what they are coming off but I'll ask at some point).
Old May 1st, 2012, 02:18 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
A special thanks to JSBriggs for helping me out with the continued mocking of Lav! Worth noting is that the file was named "boy band stubble"!
Old May 1st, 2012, 02:21 PM
LOL, a little more zoomed in than I had expected. At some point he's going to learn to not post pictures of himself anymore!
Old May 1st, 2012, 02:26 PM
"Mocking"...shit, I thought we were "celebrating"!
ac, axle
Series rear axle hub spindle badgerman For Sale - Parts 5 October 13th, 2011 01:47 PM
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
» Defender Registry
D90
95beluga
Stella
D110DC
Add your Defender
