Replace fuel pump or keep original?? 94 D-90. - Defender Source
Old December 19th, 2007, 01:17 PM
redrockrover's Avatar
redrockrover
Russell Phillips
1994 Defender 90
I need some advice from the group. I have a 94 D-90 and I am in the process of replacing the gas tank skid plate with one from Slick Rock Fab. I have the old one out and just finishing up drilling out the last bolt that broke off. I do not want to do this again any time soon so I am thinking of replacing the fuel pump. It is the original fuel pump from 94. It has about 95,000 miles. What do you think, should I replace it or just button it all up with the original fuel pump?
Russ
'94 AA Yellow
# 891
Old December 19th, 2007, 01:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
I am about to pull my tank out to do the same thing. I bought a new pump even though my current one is fine and I only have 48000 miles
Old December 19th, 2007, 01:27 PM
redrockrover
Russell Phillips
1994 Defender 90
Where did you get your pump and how much did you pay for it if you don't mind me asking?
Russ
'94 AA Yellow
# 891
Old December 19th, 2007, 01:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
rovers north 298 i think
Old December 19th, 2007, 03:07 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Just a thought, but I've seen some tubs that have an access cut out directly over the fuel pump. This way it's a snap to replace in the future. This could be easily done when you have the tank dropped in order to get the placement of the hole right. Foreseeable problems: Getting a good seal on the new access plate, cutting into a perfectly good tub, etc. If mine had 48K, this is something I would definately consider. You could start a poll, but I've got 91K with original fuel pump. If you do end up replacing your good one, definately keep that old one, put it in one of those vacuseal bags (when your wife isn't looking) and vacuseal that sucker up and add it your trail spares.
Oh, if my fuel pump fails tomorrow, I'm blaming you
-Neil
Old December 19th, 2007, 03:18 PM
cneal
Charles Neal
97 d-90, 99 & 04 disco's
Replace it. Mine went our this year with only 65,000 miles on it (97 d-90).
Old December 19th, 2007, 03:36 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Originally Posted by steinhnj
Just a thought, but I've seen some tubs that have an access cut out directly over the fuel pump. This way it's a snap to replace in the future. This could be easily done when you have the tank dropped in order to get the placement of the hole right. Foreseeable problems: Getting a good seal on the new access plate, cutting into a perfectly good tub, etc.l
The problem with that is the supports for the tub floor are directly above the fuel pump (one latitudinal one and one large longitudinal one). The old 109s had access ports like that, but they positioned the sender and stuff away from the floor supports so it could be easily done.
To do it in a 90 you have to cut out too many supports (to do it right).
We undo that "upgrade" that people have done quite often.
http://www.eastcoastrover.com/203.html
I'd say replace the pump, but if you use anti-seize and all on the bolts going back in, if you did have to drop the tank down the road at least it would be a easy job.
Email:
Old December 19th, 2007, 03:45 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Is that D90 fuel pump the same one that is in the RRC's? If it is, I've used the Carter fuel pump in a few different trucks with stellar results. It's nearly a direct drop-in, and is available anywhere.
I can't afford to spend 290 bucks a pop when I have three RRC's running at the same time. Fortunately I sold two of them and only have the one left.
Michael Slade
www.tawayama.com
Old December 19th, 2007, 03:55 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Fuel Pump
Carter P74006
Available at Napa, use existing plug
NAPA P74006
89 Cadillac Seville (puts out 30 psi, cut off connector and replace with female spades)
AC Delco EP241 (94 Camaro)(94-95 D90)
Range Rover - GM 462-23 or NAPA part number BK 610-1011
i paid about $80 a few years ago and its still going strong
3rd low and BOOT IT
Old December 19th, 2007, 04:03 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Atta boy Jimmy. That's the one.
Michael Slade
www.tawayama.com
Old December 19th, 2007, 09:19 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Thanks Mike. Sorry for putting out bad gouge.
-Neil
Old December 19th, 2007, 10:24 PM
-Neil
Snark. You navy guys and your gouge. Thats G2 man!
Old December 19th, 2007, 10:45 PM
redrockrover
Russell Phillips
1994 Defender 90
Thanks for everyone’s help. I went ahead and got one from George at Rovers Down South. I did not see the Carter 74006 in time and already ordered one from George. Next time I will do the Carter. George did take care of me just like he always does. Thanks for the help and I will post some pictures of it when I get it back together.
Russ
'94 AA Yellow
# 891
Old December 22nd, 2007, 10:24 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I did the Carter conversion a while back. It turned out to be more noisey than the origional that I replaced. (it had about 80k miles on it) I suppose the Carter might have been faulty but it worked.
I didn't like the noise so I put a Rover pump in and now keep the Carter and some small clamps and hose in my Defender as a spare.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
90, ac, d-90, fuel, original
td5 fuel pump in a 300tdi Muscat Defender Technical Discussions 11 April 8th, 2010 10:35 AM
Fuel pump issue or ??? 48vphantom Defender Technical Discussions 12 December 19th, 2005 08:04 PM
Fuel Pump Issue bjenk Defender Technical Discussions 12 December 5th, 2004 09:00 PM
Fuel Pump / Sender 95 D-90 Nigel Buchan For Sale - Parts 1 November 20th, 2003 11:03 PM
